ALBundy
Founding Member
- Dec 4, 2004
- 11,610
- 38
The clunking is due to shifting speed and its from the drive shaft free play. Even after I refurbished it the clunking sound is still there but slightly lesser. 3 years later its loud again
As for the guibo, replaced mine earlier this year together with the long shaft mounting bearing. Basically, the failure is caused by the heat from the exhaust. When the Guibo fails, there will be a vibration. Just place your hand on the transmission tunnel and you can feel it.
The LSD on the e46m3 is derived from the e36evo, similarly the engine. The engine was bored slightly and compression was increased
