my E30 320 underpower...help!
jeembo
i've hv quite a problem here...it seems that it has no pickup at all and no top speed oso...it can only reach until 110kmh even a kancil can overtake me.please all the sifu's share some tots.Thanks!
bring your car to the official tt i am sure something can be sorted out.
erhhh change car!...JOKING!
seriously something wrong w ur car....
go send to mechanic-loh
For a BMW to have such a low top speed, there is no question here and send your car to any good and reliable + reasonable workshop you know.
...one more thing i noticed that the fuel comsumption is very high...say like RM80 for abt only 300km drive...car has been serviced...i just got this car last month and I'm totally new to this UDM world...
well bro,
there's many possible causes..
if your engine is lack of power, it could be:
1. incorrect ignition timing..
2. faulty spark plug..
3. fuel injection or carburettor malfunctioning (what bimmer are you use?)
4. brakes binding.. (well, it's make sense)
5. clutch slipping.. (are you using manual or auto?)
6. etcetera..
if you're using manual transmission,
and the car can't go faster than 110km/h,
and the fuel consumption is high..
i guess, more to clutch slipping problem..
send your car to workshop..
metalrizca said:
well bro,
6. etcetera..
If yours is auto, are you aware of the existance of the so called "kickdown switch/button" located under the throttle pedal? For quite sometime when I newly bought the car, I was driving around with top speed around 110km/h also...until I figured this thing out on my own by accident. Just to share my experience if it helps...
the kickdown switch is just like dropping gear right? It shouldnt affect top speed, or am I wrong?
kickdown switch button..?
hmmn..
hoh..? :eek:
no, no, no..
do not press that button..
it will detonate explosives that release the roof of your car..
then, eject you out from your car seat..
ha ha ha.. :D
yup..
kickdown switch is kinda to downshifting gear..
metalrizca said:
well bro,
6. etcetera..
fuiyoh..!!!!
sifu.....sifu....!!!
How come my car cannot drive straight at 30kmh....keps going round and round and round.
yikes!!
c'mon aar bro Zoggee..
i'm nobody..
we're helping each other..
and have fun here..
bak tajuk lagu scorpions..
what you give, you get back..
well, nobody's perfect..
ehh.. :eek:
did i mention that i'm nobody..?
he he.. :D
just joking..
metalrizca said:
yikes!!
i'm nobody..
and have fun here..
ehh.. :eek:
he he.. :D
just joking..
His normal reply, dude
Nothing personal:cool:
Theres meaning (as always) in his reply
And as i have mentioned, get the car to the mechanic, no way theres any switches or any buttons that can hold your car to 110KMH top speed only.
hi all....thanks for all the output, here are what i have done...
1. changed the spark plug (free) sponsored by my wireman
2. clean the distributor cap...changed the distributor vacuum pipe, found leakage(rm28)
3. changed my exzos (rm320)
later this evening I'll go check my manifold gasket cos been hearing leaking sound.
a bit difference in performance...and i suspect my clutch is slipping too....anybody knows how much it'll cost me to overhaul? is it somewhere around 3K?
Thanks!
alrite now... I would later do the valve adjustment...does anybody know the valve clearance for this?
valve clearence..?
what type of bimmer engine..?
still dunno what car you drive..
valve clearence (intake and exhaust)
M10 engine
cold - 0.20mm
hot - 0.25mm
M20 engine
cold - 0.25mm
hot - 0.30mm
M30 engine
cold - 0.30mm
hot - 0.35mm
M40 engine
hydraulic adjusters
metalrizca said:
valve clearence..?
M10 engine
cold - 0.20mm
hot - 0.25mm
M20 engine
cold - 0.25mm
hot - 0.30mm
M30 engine
cold - 0.30mm
hot - 0.35mm
M40 engine
hydraulic adjusters
what if the engine has undergone head skimming what is the valve clearence?
dunno..
i'm no specialist..
he he..
we have sifu here..
any sifu can answer the question..? :D
metalrizca said:
well bro,
n wht is the solution for this problem?
