erica34;650986 said:looking forward to checking out your ride. i'm guessing your setup is geared towards quick spool and will make a nice daily drive.
pussy;650998 said:
tehyw;651070 said:dammmit.... i also want turbo now..... just that i duuno where u all get all this kits....
tehyw;651160 said:damn... u all spoil my 3L dream.. wanted to do stroker...
ramsing;651189 said:no need stroker la..unless u want to get high hp. then more cc the better. bang for buck, FI la. turbo is best, u wait until fandango's car is ready. at 2000rpm, 500nm of tq. the car will be drifting everytime come out from junction or traffic light. u think Initial D was bad??? u havent seen Initial Fandango yet, he will use every longkang to makan the corners!!!!![]()
tehyw;658032 said:hi guys, i decided to save up and go for turbo!
can tolong sikit? ie which turbo to buy, and can unichip support a soft turbo? 0.5-0.6 bar..
fandango;658108 said:Piggybacks are useless in a BMW DME.
Unless you are going to do all-balls-out modifications to your beemer, you would be wise to opt for DME in-chip tuning from www.racersmarket.net or www.millerperformancecars.com.
fandango;668308 said:The car's been running for over a month now; had all sorts of vacuum and boost leak issues. Became well acquainted with public transport... I think I finally fixed the last leak between icv and manifold (replace new o-ring) and got boost up to 0.7 bar or so from 3.5k rpm to abt 6krpm in 4th.
I do think the turbine rotor is a bit oversized by 4mm so boost is a little late. Waiting to get clutch replaced first before going to dyno.
