e90 325 window trim
racheltoh
anyone has this issue?
note: cannot use double sided tape, 3m tape for remedy...:(
A fastening clip or stud has probably broken Rachel. Just take it to a dealer to be fixed. :wink:
Ops... then its this:
Item 1, Part no: 51 33 7 906 902, "Channel cover, exterior, door, front right" High gloss shadow line
Must be broken clips or loose clips. The SC will know what to do.
Normally this will only happen when someone try to korek your door trying to get in.. :eek: Any korek marks?
That's your window trim as you rightly titled this thread, and that's the part that's come loose. It's not a big issue and can be fixed easily, Rachel.
Take a few pictures from a clearer angle la RT, then we'll know what exactly is hanging out of your bf.
racheltoh;550629 said:
what is Number 7
Number 7 is part of the smoking package that will suck the smoke from the cabin and release from the tail pipe. :rolleyes:
babe....
i think someone got itchy fingrs lor
trying to see if the thing is bendable...
maybe u can take it out and bend it the other way round...?
what is Number 7
No lar, not item 7. It should be item 1.
item 7 is the rubber gripe for the window. Item 1 is the lower window trim.
If the clip below is not broken, you can press it and it will latch on.
The batang is keras...if I do press it n put double sided tape..it will break.
Anyway back to the 'hospital' soon...
Looks more like damage instead of wear and tear. Possibly by car wash dude's cloth catching the trim??
Agree on the dress tho :p
