racheltoh Club Guest Joined Apr 5, 2008 Messages 885 Points 0 Aug 10, 2010 #1 anyone has this issue? note: cannot use double sided tape, 3m tape for remedy...
Spaceman Club Guest Joined Jan 18, 2005 Messages 1,163 Points 38 Aug 10, 2010 #2 Where is this? Can't see. Can post up another pic further away?
astroboy Well-Known Member Joined Dec 15, 2006 Messages 8,734 Points 63 Aug 10, 2010 #3 That's the front windscreen trim... also known as "Supporting Ledge", part code: 51 13 7 133 292 http://bmwfans.info/parts/catalog/E.../N/2007/february/browse/vehicle_trim/glazing/ Item No 9:
racheltoh Club Guest Joined Apr 5, 2008 Messages 885 Points 0 Aug 10, 2010 #4 no la. its at the door!
Schwepps Senior Member Joined Aug 2, 2006 Messages 2,746 Points 0 Aug 10, 2010 #5 A fastening clip or stud has probably broken Rachel. Just take it to a dealer to be fixed. :wink:
astroboy Well-Known Member Joined Dec 15, 2006 Messages 8,734 Points 63 Aug 10, 2010 #6 Ops... then its this: Item 1, Part no: 51 33 7 906 902, "Channel cover, exterior, door, front right" High gloss shadow line Must be broken clips or loose clips. The SC will know what to do. Normally this will only happen when someone try to korek your door trying to get in.. Any korek marks?
Schwepps Senior Member Joined Aug 2, 2006 Messages 2,746 Points 0 Aug 10, 2010 #8 That's your window trim as you rightly titled this thread, and that's the part that's come loose. It's not a big issue and can be fixed easily, Rachel.
C climenta Official Member Joined Oct 23, 2007 Messages 1,733 Points 0 Aug 10, 2010 #9 Take a few pictures from a clearer angle la RT, then we'll know what exactly is hanging out of your bf.
astroboy Well-Known Member Joined Dec 15, 2006 Messages 8,734 Points 63 Aug 10, 2010 #10 racheltoh;550629 said: what is Number 7 Click to expand... Number 7 is part of the smoking package that will suck the smoke from the cabin and release from the tail pipe.
kayzhen911 Club Guest Joined Apr 23, 2010 Messages 614 Points 18 Aug 11, 2010 #12 babe.... i think someone got itchy fingrs lor trying to see if the thing is bendable... maybe u can take it out and bend it the other way round...?
jarance Founding Member Joined Dec 4, 2004 Messages 14,743 Points 63 Location KLlang Aug 11, 2010 #13 racheltoh;550629 said: what is Number 7 Click to expand... No lar, not item 7. It should be item 1. item 7 is the rubber gripe for the window. Item 1 is the lower window trim. If the clip below is not broken, you can press it and it will latch on.
ahmz Club Guest Joined Aug 12, 2009 Messages 127 Points 0 Aug 11, 2010 #14 Funky dress rachel! Very psychedelic....
Schwepps Senior Member Joined Aug 2, 2006 Messages 2,746 Points 0 Aug 11, 2010 #16 Shaggedelllic place to hang key fob...
racheltoh Club Guest Joined Apr 5, 2008 Messages 885 Points 0 Aug 11, 2010 #17 The batang is keras...if I do press it n put double sided tape..it will break. Anyway back to the 'hospital' soon...
X6M Club Guest Joined Sep 27, 2009 Messages 40 Points 0 Aug 11, 2010 #18 ahmz;550863 said: Funky dress rachel! Very psychedelic.... Click to expand... nice LV bag too...LOL....:wink:
E46Fanatic Club Guest Joined Dec 7, 2004 Messages 2,893 Points 0 Aug 11, 2010 #20 Looks more like damage instead of wear and tear. Possibly by car wash dude's cloth catching the trim?? Agree on the dress tho
