QD250;522054 said:anyone knows where to repair the cigarette lighter?
cannot use my mobile charger....
affan66;522068 said:does the charger work?
On mine, the fuse of the charger blew. Check both fuses.![]()
katakijau;522328 said:my cigarete lighter also have problem. Sometime when pushed, its doesnt spring back. But the heater is ON.
Anyone know this problem?
jarance;522339 said:The heater release spring is bend. When the temperature is correct, it will expand and allow the lighter to pop out. Due to people using charger, this spring got bend a bit. Quite hard to explain. Only way to check is to compare with the one that is working..
katakijau;522342 said:Thanks Jarance, I will try to see that spring.
I think it can be bend to its original position.
jarance;522090 said:why I never think about the charger fuse? :smokin:
QD250;525705 said:Guys,
problem solved... it was in fact the fuse.... changed it and presto the ciggy lighter works....
but on the morning after i repaired the fuse...... my car have major damaged.....
will post when the physical, emotional & spiritual issues have been stabilised....
