initialM
Official Member
- Jan 30, 2006
- 8,593
- 63
Today had a short run with a white civic dunno which model coz it's debadge but got twin exhaust. I dont just pay 2.8cc roadtax for nothing. Dont race on the road. Anyway nice try.
E46 328 spec.
Maximum power
SAEnet
195.7 PS (193 bhp) (143.9 kW)
@ 5500 rpm
Specific output
SAEnet
69.1 bhp/litre
1.13 bhp/cu in
Maximum torque
SAEnet
279.0 Nm (206 ft·lb) (28.5 kgm)
@ 3500 rpm
SpecificationsCivic Type R
from RM199,800
EngineEngine Type4 Cylinder 16 Valve DOHC i-VTEC Fuel Supply SystemPGM-FI (Programmed Fuel Injection)Bore & Stroke (mm)86.0 x 86.0Displacement (cc)1,998Compression Ratio11.7:1Maximum Horsepower [PS(kW)@rpm]225 (165)/8,000Maximum Torque [Nm(kg-m)@rpm]215 (21.9)/6,100
Specifications
Civic 2.0S
Civic Concept M
EngineEngine Type4 Cylinder 16 Valve Chain-Driven SOHC i-VTEC4 Cylinder 16 Valve Chain-Driven DOHC i-VTEC4 Cylinder 16 Valve Chain-Driven DOHC i-VTECFuel Supply SystemPGM-FI (Programmed Fuel Injection)PGM-FI (Programmed Fuel Injection)PGM-FI (Programmed Fuel Injection)Bore & Stroke (mm)81.0 x 87.386.0 x 86.086.0 x 86.0Displacement (cc)1,7991,9981,998Compression Ratio10.5 :19.6 :19.6 :1Maximum Horsepower [PS(kW)@rpm] 140 (103)@6,300155 (114)@6,500155 (114)@6,500Maximum Torque [Nm(kg-m)@rpm]174 (17.7)@4,300188 (19.2)@4,500188 (19.2)@4,500TransmissionTop ↑Transmission TypeElectronically Controlled 5-Speed AutomaticElectronically Controlled 5-Speed Automatic with Paddle Shift ControlElectronically Controlled 5-Speed Automatic with Paddle Shift ControlClutch TypeTorque ConverterTorque ConverterTorque ConverterSteeringTop ↑TypeRack & Pinion with Power-assisted (Hydraulic Power Steering)Rack & Pinion with Electric Power Assist (EPS)Rack & Pinion with Electric Power Assist (EPS)Overall Ratio13.7313.6213.62Turns, Lock to Lock2.672.652.65Turning Radius (m)5.85.85.8BrakingTop ↑FrontVentilated DiscVentilated DiscVentilated DiscRearSolid DiscSolid DiscSolid DiscSuspensionFrontMacPherson StrutMacPherson StrutMacPherson StrutRearIndependent Double WishboneIndependent Double WishboneIndependent Double WishboneDimensionsTop ↑Overall Length (mm)4,5404,4504,450Overall Width (mm)1,7551,7501,750Overall Height (mm)1,4351,4351,435Wheelbase (mm)2,7002,7002,700Treads (Front) (mm) 1,5001,5001,500Treads (Rear) (mm)1,5251,5251,525Ground Clearance155150150Weight (kg) 1,2401,3151,315Wheel Size 16 x 6 ½ J17 x 7 J17 x 7 JTyre Size 205/55R16215/45R17215/45R17Spare Wheel (Steel) and Tyre Size15 x 4T T135 / 80D1515 x 4T T135 / 80D1515 x 4T T135 / 80D15Fuel Tank CapaCivic (Litre)505050
E46 328 spec.
Maximum power
SAEnet
@ 5500 rpm
Specific output
SAEnet
69.1 bhp/litre
1.13 bhp/cu in
Maximum torque
SAEnet
@ 3500 rpm
from RM199,800
Specifications
Civic 1.8S & Civic 1.8S-L
from RM114,980 & RM119,980
Civic 2.0S
from RM130,980
Civic Concept M
from RM137,980
