Auto to Manual
actually my longshaft is a combo between a m20 manual longshaft and my own m50 auto longshaft. the mech had to mod both to fit. he used the m20 shaft with the m50 front and rear couplings. No vibration whatsover.
Went to dyno just now, here are the results:
peak power: 175whp at 6200rpm
peak torque: 220wnm at 3600rpm
Car has a conforti chip. Assuming a 20% loss, their claims of 210hp and 260nm is quite accurate.
read this: http://www.pumaracing.co.uk/POWER3.htm
excerpt from the article:
True Transmission Losses
So is there any way of really measuring the true transmission loss of a car? Yes - only one - by measuring the flywheel power on an accurate engine dyno, the wheel power on an accurate chassis dyno and taking one away from the other. There is no way on God's green earth of finding out the true transmission loss just by measuring the power at the wheels.
So hopefully that's got you all thinking a bit more now instead of just taking for granted the "flywheel" figure you were given last time you took your car to the rollers. Even worse is the fact that some of these software systems allow the operator to just programme in the % transmission loss he wants the system to add to the wheel figures. So if that isn't a nice easy way to show some big fat flywheel bhp then I don't know of a better one. It's certainly a lot easier than actually doing some proper development work to make the engine perform better - just dial in a bigger transmission loss and bingo - the same wheel bhp now turns into a bigger flywheel bhp - happy customer, happy dyno man - just a shame it was all sleight of hand. See the end of this article if you doubt that this sort of thing really happens.
So what should you do when you take your car to a rolling road? Firstly, make sure you get printouts that show the wheel bhp and not just the flywheel bhp. Then at least you can see if they look sensible in comparison. If you have a desperate need to know the flywheel bhp then you will have to estimate it - there's no other way short of using an engine dyno.
The average front wheel drive road car with between 100 and 200 bhp loses about 15% of the engine bhp as transmission losses.
The average rear wheel drive road car with between 100 and 200 bhp loses about 17% of the engine bhp as transmission losses.
The 2% increase in losses over front wheel drive is because the differential has to turn the drive through 90 degrees at the back axle which soaks up a bit more of the engine's power. Copyright David Baker and Puma Race Engines
4wd cars will have higher losses because of the extra differentials and other power transmission components. The tyre and main gearbox losses will be the same though. Correlating the performance of vehicles with the both 4wd and 2wd options (Audi's and the Sierra Cosworth are examples) shows 4wd transmission losses to be about 5% higher than rwd. 22% seems to be a good average.
What each individual car loses is an unknown - it will depend on tyre sizes and pressure, suspension angles and other things, but it shouldn't be far from the figures above. For sure though, no 2wd car in the world, unless it has flat tyres and a gearbox full of sand, loses anything like 30% of the engine's power in the transmission and tyres as many rolling road operators would try to have you believe. In general though it is fair to say that low powered cars have higher % losses than high powered cars. This is because some of the frictional losses are independent of engine power and so represent a bigger drain on a small engine. For example, a 60 bhp Fiesta will have around 14 to 15 bhp total transmission and tyre loss (25%) whereas a 90 bhp XR2 will only have about 17 to 18 bhp loss (20%) - a smaller % obviously. By the time you get to RWD cars with engines in the 300 to 500+ bhp range, losses can eventually drop to as little as 12% to 14% or so.
Converting wheel bhp to flywheel bhp and vice versa
To reflect the fact that % losses are high for low powered cars and vice versa I use the following equations which have been found to correlate well with real world transmission losses.
FWD cars - add 10 bhp to the wheel figure and divide the result by 0.9
RWD cars - add 10 bhp to the wheel figure and divide the result by 0.88
4WD cars - add 10bhp to the wheel figure and divide the result by 0.84
To estimate the expected wheel bhp from a known flywheel bhp just reverse the equations
FWD - multiply flywheel power by 0.9 and then deduct a further 10 bhp
RWD - multiply flywheel power by 0.88 and then deduct a further 10 bhp
4WD - multiply flywheel power by 0.84 and then deduct a further 10 bhp
Remember, these percentages are not "gospel" - they are good realistic averages. The measured wheel bhp can change depending on tyre pressure, tyre size, suspension angles and other things which won't affect flywheel power - so the actual transmission loss % will also change. It pays to try and standardize as many of these things as possible if you intend to do a series of power runs over a period of time. Always use the same tyre pressure because this is a factor which can easily change from day to day and make sure the tracking is correct on a fwd car. Copyright David Baker and Puma Race Engines
Also please remember that the manufacturer's claimed power figures for a standard car are not gospel either. Even engines in perfect condition can vary by plus or minus 5% due to manufacturing tolerances. High mileage or poorly maintained engines can be well below the claimed output. It is no proof that a rolling road flywheel bhp estimate is correct just because it comes out as the same figure as the manufacturer's. Always compare with the measured wheel bhp to see if the transmission losses agree with the data above.
