terry8
- Joined
- Feb 15, 2009
- Messages
- 461
- Points
- 0
Hi gurus,Really need your opinion. My water tank sensor lit up and I found my water tank empty so I filled the tank and also was careful to bleed the air out of the tank. After one day the tank was empty again. I took to a workshop which did a pressure test which showed that there is no leak because the pressure did not drop. The mechanic bleed the tank of air and filled it with water. In 24 hours, the tank is again low on water.What can be happening ? Where is the water going to ?Terry
