Found the specification thru mr google....
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4510 x 1740 x 1445
Interior dimensions (LxWxH), mm 1905 x 1455 x 1165
Wheel base, mm 2700
Treads (F/R), mm 1505 / 1505
Ground clearance, mm 145
Curb vehicle weight, kg 1480
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 5
Min.turning radius, m 5.6
Fuel tank capacity, l 60
ENGINE
Displacement, cc 1998
Engine model 3S-GTE
Max.power (Net), kw(PS)/rpm 260 ps (191.23 kw) / 6200 rpm
Max.torque(Net), N*m(kg*m)/rpm 33.0 kg*m (323.62 N*m) / 4400 rpm
Power density 5.69
Engine type Serial 4 cylinder DOHC16 valve turbo
Engine information
Fuel system EFI (electronic fuel injection) (Ci (central injection)
Turbocharger Turbo
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 9
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.4
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 215/45ZR17
Tires size rear 215/45ZR17
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front Strut type coil spring (stabilizer attaching)
Suspension system, rear Double wishbone type coil spring (stabilizer attaching)
