Top speed different between m5 and m6
hi crg33, by reading your words i can tell you, your car is perfect already. the max speed M can go with std ecu is 275km and
with open ecu (mapping) max is 330km. sometime if you drive face front wind or back wind that also course on your speed. cheers.
CRG33;439197 said:
ya lo. nak try lain mah. eveytime use the same mei:eek:
ni bukan lelaki ni..ni dah kira jantan..:wink:
so what model u looking for after this..:listen:
The M6 is very, very fast, but it could be faster, as it stands, it tops out at just shy of 200 mph, whereas the M5, tops out at the exact same speed. The advantages of the M6 over the M5 are numerous; the M6 has a carbon roof which lowers the center of gravity making it handle better than the M5, and the obvious fact that is in a coupe versus a super saloon.
