start engine kereta gegar
junior_e90
Hi guys,
. E90 aku ade problem biler aku start kereta then kereta gegar. Biler nk accelarate, macam underpower and then kereta gegar. aku bau petrol biler start kereta pagi tadi. Plzzz help me :)
check the fuel lines bro. aku rasa maybe ade leaking sane so pressure from fuel pump not sufficient to the engine
Many possibilities
1. Fuel pump
2. Fuel filter
3. vacuum leaks
4. MAF dirty
5. ignition sensor
6. coils / plugs
Sadly its hard to diagnose such issue.
aku dah check workshop and problem dier dengan coil n spark plugs. 4 spark plug kena tukar each RM55 and 1 coil around RM100++. . ok ke price dier yang dier quote tu?
I also suffer from engine vibration during morning start ups, already changed spark plugs but problem still persist,
might change the coil plugs
bro, pegi check & repair workshop kat mana? rasenya ak face the same problem la.tqs
Ori BMW NGK Plugs is just RM40 each from Bavaria Auto and Ignition Coil is RM85 each.. Those are DIY possible
Guys, i also facing the same problem..but case i worst than that i think la.. almost 2 weekd at workshop. Semua tukar da tp still lg start enjin ada problem and somtimes power hilang bila jalan dan mati2. My mekanik pun pening..throttle body da tukar tp sama jugak. Adakah masalah pd ECU(control unit)
Epul2801, sounds like u need to tukar mechanic/worskhop.
Ignition coil can diy diagnose by pulling out to check for vibration. I always have extra ignition coil cause easily diagnose and replace.
