REDUCE SOUND OF LIFTERS
snake
Hey thr guys...can any1 tell if thr is a way to reduce the hydrolic lifters sound..i was told that it is possible but i amyet to find out...be more than glad to know... :rolleyes:
Change to new lifters. It is the only way. Your M40 uses hydraulic lifters and these are not servicable items.
*psssst: If the driver loses a few pounds, there will be less load on the engine......*cabutz*
if i am goin to change lifters i might as well change engine.....recently some1 that you know has done something which only cost him less than RM30 to reduce the sound........i thought u might knw
who u whispering too psssttttt all and wait dont run away !!!!! wey stop running lah ......
Originally posted by pussy@Jul 7 2006, 02:28 PM
must be oil you are using... change it !!
i am using shell 15/50 isnt that the common oil used and hw does the oil effect in the sound . Do i need to use any additional adatives which can help.....well your budak did that but he dont want to tell i guess u the sifu would hv told him...........help....help... :(
try use additional adatives Bardahl II or Nasa II...
i think can help....
cheers
you must have missed the TV advertisement about X1R...
interviewed one of our own member some more....
i wonder who is that???? :rofl: :rofl:
cabuttzzzz.......... :ph34r:
Try STP from USA. It help even to the worst case; worn out piston rings. But in this case not permanently lar..
If its knocking hard(rattling during cold start) change the hydraulic lifters. Using additives or changing to thicker wt oil won't change the situtation.
Tell me more.....tell me more.....a RM30 soulution to quiten hydraulic lifters sound s like something to be shared! :eek:k:
Originally posted by snake@Jul 12 2006, 02:36 PM
its definately not a permenant solution but it helps for about 3000km so which means for every oil change ...... well i amgoin to try the Nasa/Badhall hopefully it works...hehehe
I have the same problem and have tried all kind of solutions... b waiting for your finding of that Nasa/Badhall.
Keep on update...
snake, i believe the lifter sound has nothing to do with it, in other words, the hidraulic lifters are fine..it's your drag lever worned or the oil pipe feeder above the lifters clog..
regards.
apaprently using mineral oils help..thats from a friend who also drives an E30 with the M40b16 engine...
personally, when they rattle, its time to change the lifters..besides, they dun get changed that often.. i've changed them once and its been 50000km..still no death rattle..;)
