humms
- Oct 6, 2013
- 88
hi kw930, thanks for the compliments! it's quite easy to remove it actually. as you can see from my above pictures, you just need to peel it off. the more layer you have, the easier for the plastidip to come off as a whole. however, you may need to start peel it off at the edges and roll it / peel it just like how you peel a tape off.kw930 said:Hi humms, nice job you've done.
May I know how many can needed to spray all 4 rims?
Since you says it's reversible, may I know how easy to remove the coating from the rim?
if you dip it well, the plastidip will coat the entire surface area and you may need to use a toothpick or a sharper object to puncture a small hole on the surface of the plastidip. i've removed before some of plastidip on some other things.
for some of the area that did not coat well, ie not 100% full coverage, that requires harder work such as usage of thinner and hard rubbing.
