xcrave
- Joined
- Nov 16, 2010
- Messages
- 720
- Points
- 0
Guys I donno where to start cause all i read point to my water pump... But still I want Sifu advice...As i was driving, today early morning.,... My Radiator Sign Pops Up... So i ignore it till i reach work cause its turn on and off.Then Before I embark home, I filled in the Radiator with "TAP WATER" cause i dont have anything else in my booth since i always stand by 2 bottle of de-ionized water...Then roughly about 15 minutes drive i was shocked off my boots... THE TEMPERATURE IS RED!!!I keep driving till i reach a Gas Station and the car died Just as i enter in... I quickly open the booth and splash water ehere i think its safe....It Was Raining heavily and my temp warning from my "lost" ambient temperature showing -40 Degrees...I let it cool a bit and using wet towel i open the radiator and open the bleed screw!To my amazement the water are all there not a single less drop but the bleed screw only emits steam not water....Then having no option i bought 1 coolant from Petronas (RM 20) when the water subside add all in and start engine temp go back normal but i keep bleeding the radiator but no water come out even after i pour somuch water in the reserve tank... i see that there is water coming out from the small hole from the side... Is the Pump still alive??? then i close everything up and drive home... IT overheat again when i reach home...Now i let it rest on its on...Questions...Was it really my pump is busted???Or i fill coolant and water badly that i didnt bleed it last time... please help...What can i do at home for self check...?It dawn to me that a lot of problem starting to arise... huhuhuh feel cheated....
