At my last service in Dec 08, the mechanic said the suspension needed an overhaul at the next serviceUnfortunately, was forced to take a trip to Kundang and completely killed the suspension .... so i had the car jacked up to see what needed replacing and found1)Entire suspension had to be replaced2)engine was leaking oil and some other leak at the bottom of the car near the middle sectionWhile fixing those problems found the crankcase breather hose soft and lower arm bushes also on their last leags .....sigh also had the engine degreased to make sure all the leaks were fixedthen suddenly all the brake lights were on all the time (the brake switch had died)Managed to DIY the brake switch so that was only RM40/- for the switch (the only cheap fix so far)While doing the balancing and alignment found the engine leaks were fixed but it appeared that the power steering oil carrier pipes were leaking ......sigh Suddenly the car is not idling properly and the ABS light is on, so sent it in for a check and confirmed1)the 2 power steering oil carrier pipes need to be replaced (only topped up the steering fluid as a temporary measure until i have time to send the car in to change the pipes)2)Front 2 ABS sensors and and ABS pump no signal3)mechanic suspects fuel injectors etc maybe the cause of the high idle (800-1k rpm)4)Also maybe have to change the engine and gearbox mountings .... sighMade an appointment this Saturday at 8.30am to change the oil carrier pipes and check the ABS and rough idle ....... Now so worried about what will go wrong next ..... seems to me, everytime i fix something .... something else starts acting up ..... sigh ..... will it ever end?
