ABS Light & Rough Idle
Terri
Sorry but i need some quick fixes as i'll be going to my mechanic tomorrow morningIn addition to the steering hoses that need to be replaced, i need some advice on the following :-ABS LightIt comes on when i brake hard or hit a bad bump but doesn't stay on all the time (intermittent problem)Computer Diagnostic last Saturday said1)Front 2 sensors &2)ABS Pump NO SIGNAL!I have compliled a checklist on the ABS based on on all the previous posts from members but was wondering if anyone knows what should be the most likely causeNOTE : I'll just be doing checks and hoping for a quick fix as budget wise i'm not prepared to replace the parts tomorrowAlso my brake system has not been flushed since AB flushed it in Jan 2004 - i think it needs a flush but my mechanic says it's fine and won't do it ....I'll be changing all the 4 brake hoses next month and then my mechanic won't have a choice but to bleed the system thenI've noticed that whenever my ABS gave a problem and i sent it to AB, they always flushed the entire braking system ......Rough IdleMy car has started idling abit rough from 800-1000 rpm at startWhen the aircon is switched on the idle becomes smoother and normally stays at 800rpmthe fuel filter hasn't been changed in years (i bought a new 1 just in case) and i also bought new spark plugs (2 legged Bosch original) also have prepared the engine vaccum hoses(crankcase breather hose and rear engine connector just changed)i'm also trying to find Redline/ STP Fuel Injection cleaner etcThe Checklist i compiled from previous members posts is really long ......Anyone has any ideas on the most likely cause for ths problem?(I haven't had time to get to Brothers in Ampang to find the cleaners etc that i need : MAF Cleaner, Brake & Brake parts cleaner & Contact Cleaner and Redline/STP Injector cleaner etc Carefour/Jayajusco etc don't sell them they sell Gold Eagle Injector cleaner but too afraid to try that brand ..... sigh)Some HELP would be greatly appreciated!
