hi i'm new in this forum. i'm not very familiar with bmw because this gonna be my first bmw that i'm gonna purchase so i need some advise between 325ci and 330ci. in fuel consumption, maintenance and performance.. much appreciated for the help..
LOP82;255436 said:hi i'm new in this forum. i'm not very familiar with bmw because this gonna be my first bmw that i'm gonna purchase so i need some advise between 325ci and 330ci. in fuel consumption, maintenance and performance.. much appreciated for the help..
emaveric;259738 said:Why Ci is much more expensive than sedan?
tombstone;258610 said:318ci ?? m44? isnt it a m43 1.9 for the first batch...
emaveric;259998 said:For 328 ci, manufactured only in year 2000? There's one 328 ci selling where the dealer claimed its from year 2002
bmwcar;260026 said:328ci manufactured till Q3 2000. Then replaced by the 330ci.......there is no 328ci manufactured in 2002...it may due to the fact that AP's are only for cars up to 5 years old and hence this car could have been declared as a 2002 model... run the vin number through realoem.com and check.....
seen that car in the classified...think asking for RM15xK.....
emaveric;260042 said:The one i saw in motortrader comes with wide b/k. My guess is probably around 180k? a little pricey dont you think?
bmwcar;260109 said:quite pricey actually...for a 2000 model as the 328ci production was stopped in that year.....just get the vin number and run it through realoem.com....
i think the price for a 2000 328ci should be about RM115K to RM130K depending on condition, mileage and options....add about RM10k max for a tastefully and well installed widebody and you should be looking in the region of about RM125K to RM140K max......
BlackCat;260009 said:Yes you are right, its an M43 engine... [and I must say that its one of the best 4 pot engines for the E46 series - least problematic of all, and that means good maintenance cost i.e. $$ savings. IMHO]
BlackCat
emaveric;260242 said:Noted, any known issue with 328 engine? I will try to avoid 318i with all the complaints here...scary
emaveric;260256 said:Yes i did some quick research & found that it not just affecting 328ci but other models as well. So far happened on 323ci, 330ci & even 325 sedan?
Anyone experience similar failure? How much does it cost to get it fix? Any noticeable symptoms?
Bmwcar, many thanks again! You are very very helpful
