Hi guys,
I dont know if you can help me diagnosing wich part I need to replace, but I will just tell you below why I think I need a fuel pump.
I am having the following errors on my DME:
32/14 - Activation, solenoid valve, fuel-circuit changeover
85/08 - Signal, CAN ASC 3
34/02 - Activation, solenoid valve, exhaust flap
7E/12 - Activation, solenoid valve, tank-leak diagnosis pump
7F/02 - Activation, solenoid valve, suction-jet pump
Besides that errors, the car just stops when (I believe) is hot but it wont show as hot in the gauge temperature indicator (I just feel that it is way too hot than normal).
And sometimes the car cranks but does not start and I need to try a few times or wait a while until it starts up.
What it could be? I think error 32/14 is triggering errors 34/02, 7E/12 and 7F/02, and error 85/04 is just ABS rear sensor. I have not tested the fuel pump relay yet because I dont know how to do it.
I think if I had any cooling issues it supposed to show up on BMW scanner right? Errors such as thermostat or water pump
Thank you
