Eibach Pro Kit Springs - E30
dvng
How good is these springs for the E30, I've been offered RM1100/= (new) by someone..is it a good buy...
if you use those springs......
i guess you won't "bounce" like that gurl on your avatar.....it will be firm ride all the way.......kekekeke!!!!
price for new is reasonable
but beware, it must be matched with proper absorbers or else it will either be too hard or too soft.....then you will be bouncing around like your avatar.......hehehe!!!!
if i installed these springs in the car, then any gurl who sits in the car wont have their tits bouncin about, aw shucks, then i better stick to stock springs then...
not only will their t.i.t.s. bounce.......your ba.lls will bounce too.......
hehehe......
jeff yours normal eibach laa.......pls know the difference.....
yours bounce slow slow wan......
dvng wants the pro kit to make it to bounce all over the place....
kekekeke...!!!!!!
kekekeke...!!!!!!
yeah..lar, i didn't say I was using Pro-kit..wat?
tat why... my one bounce terbalik...lor :yes: :yes:
Originally posted by jeffreyewe@Jul 21 2005, 12:49 AM
I'm using Eibachs..thus look at my avatar.
whah..!!! using Eibach spring and the girl bounce upsidedown wan ah.. :huh:
I'm using Apex sports spring...and Apex Sport Absorbers.!! Happy with it.
Used The combi of Koni shocks and Apex spring...last me 40K only.
as for Eibach.....??? they are good... but not to my liking leh...very soft wan.. :(
Originally posted by Alvin@Jul 21 2005, 02:32 AM
I also use Eibach but mine custom made spring rates with coil overs. Ok what!
oi cipot...!!! your Eibach is for the Always in the worshop CAR la...special wan.. :p
Well at least my 320i went to track. Yours le? Keep ar. Kenot bring ar. Scare too slow izzit! kekekekeke
ekekekekekek....... the challenge! :yes: :lol:
Hullo Sifu
Pls advise advantages on installing coil overs..do they enhance or retard the bounce... :p :D :D :rofl:
An Eibach dealer quoted me RM1K, but according to him, there are few models of Eibach Pro-Kit for E30, izzit true :dunno: ?
Thank u in advance :) .
ck, check the eibach website, they have online catalog so can see which model is yours.
Cipot Alvin.... :p
btw, when can bring an FK coilover for me... :D
Eibahc produces two lines for the e30:
1.Pro-Kit - direct replacment for OEM(lowers 40mm)
2.Sportline - recommended for trck use only(lowers 60 mm)
The eibach prokit is a progressive cold-wound spring that will lower your car 35-40mm. It is designed to be used with your OEM absorbers.
In my experience, they work best with Bilstein shocks. A lot of the e30 owners here are running on this set-up as it provides a good balance btwn ride and handling for DAILY driving and light track use.
Hope this helps.
Kevster
Do you know where I can get a set of E pro-kit, and how much would it be? I've got a set of Apex if anyone wants to swap. Too hard for my teeth!
:D
Originally posted by esterix@Jul 21 2005, 11:26 PM
Kevster
:D
Try Hup Soon in Sunway. There carry genuine Eibach stock and their prices are rather attractive too!
