E39 Zimmermann Sport Disc Rotor
henry phoong;570326 said:
Hello, for E60 year 2005 530i do u have any upgrading rotor?? Coz i was changing to 20 " dy
Bro, am travelling this month and if you need me to get the disc rotor, please let me know your disc rotor size, diameter and width.
Cheers
jp
hakim_radzuan;570327 said:
bro, we can buy from you anytime or have to order first? might want to get from you for e60 530 later..maybe next few month
Bro it all depends on my travel plans and at times can't afford the extra kilos, sometimes lucky enough to travel with my team....lot of extra kilos in terms of luggage is available.
At times, my friends/colleagues travel too,
Price may vary a little due to exchange rate.
Cheers
jp
Bro,
Thanks first ya...i will go and check, but the rotor must be same with the ori sizes?? I was plan to upgrade to bigger sizes rotor?? Any idea?
henry phoong;570497 said:
Bro,
Bro, if you upgrade disc rotor size then you also need to change your brake calipers respectively. You would need to purchase a complete set of calipers and rotors.
Am not a professional in terms of brake upgrades, you may want to check with gurus who had done such upgrades.
This Z disc rotors are after market replacement based on the car's original brake specifications.
All the best in your upgrade.
cheers
jp
These zimmers are good. direct replacement pair with ori BMW pads will do wonders especially when properly warm up.
On my E46 328
Dear UDM lovers,
My friend is travelling, anyone interested in purchasing the Z sports disc pls advise.
Thanks
JP
Dear E34 Owners,
Have an extra pair of Z sport disc(front) for E34, anyone interested pls let me know. Price @ RM.900
can u get for the E38 750i front discs? price? and what type of rotors are they, as in the Zimmerman model type? thanks
my rotor are due to change
E39 520i....any stock for this model ? Prefer COD area Putrajaya/Serdang/Puchong/Sunway
Azril 013 6767 057
anything for a e46 320?
anything bigger than my current ones?
Front 330 and back 320... do i need to change anything other than the disc rotor or it's direct replacement?
JKP,
I called u just now, but u was in discussion. Interested in getting one set of Zimmermann disc for E39. Please advise the price and the availablity. Thanks.
Sorry fellow UDM lovers, been busy with work and just saw all your request.
Will travel soon and pls advise if any of you are still looking for the Z sport disc rotors.
At present, I have a pair of front E39 disc which will fit 520i, 523i, 525i, 528i and a pair of front E34 disc.
Thanks and any clarification, pls sms @ 012-651 6090
Bro if still interested, will check for you. Normal and sport disc rotors are available. Zimmermann made
It will be a direct fit. If you require a bigger rotor then you will need to change the calipers too.
Dear UDM Owners,
I have the following brake discs for sale:
E60 - 530
Front (324mm/30mm) RM600 per piece
Rear (320mm-20mm) RM550 per piece
E39
Front (296mm/22mm) RM425 per piece
Rear ventilated (298mm/20mm) Non coated RM375 per piece
Rear solid (298mm/10mm) Non coated RM325 per piece
E34
Front (302mm/22mm) RM450 per piece
Bro, for the benefit of all, can I assume that for E34 and E39, they fit for all non-M models? 520/523/525/528/530/535/540?
JKP;674435 said:
Dear UDM Owners,
E60 - 530
E39
E34
Front (302mm/22m) RM450 per piece
No. E39 520i, 525i uses 296mm discs. 530i uses 324mm discs. Not sure about 535i and 540i though.
And also the E39 528s...
As for the E39 530 & 535, may differ according to market specifications and YOM, either 296mm/22mm or 324mm/30mm and E39 540 uses 324mm/30mm
