E30 Parts & Maintenance
bazet;714222 said:
First service after acquired my Cik Merah at Equine Park NZ Auto BMW
- new e30 steering rack ( trade in with chop chop ) RM700
- aircon compressor repair
- engine oil service + oil filter RM 72
- throttle body cleaning to solve idle problem
- workmanship RM250
Wallet lightened by RM1350 /=
me also around there le...new steering rack?..
Hi Guys,
Over the years I have collected many extra parts for my E30 rebuild project, if any of you need some parts especially on the interior side drop me a PM.
I am referring things like dashboard, steering wheel, jack, door cards and other parts. I also have a set of glass for the front doors for the 2 door unit. So you can imagine the things I have.
Happy to help if you are looking for these items and it is not about making money as if I could help restore any E30, I will chip in.
bmw131;715114 said:
Hi Guys,
You got PM. :)
hello.. i'm interested in the 2-door window glass (both sides) if scratches aren't too visible. 012 3086433. thanks.
Does anyone happens to know how much tail light gasket would cost and where to source for them? For E30 M40. Thanks.
Alejandro: I think I called one of the parts shop about these some years back. They quoted something like RM120 per side.
Thanks Nick. RM120 for new parts right? Quite costly but I need it badly. Mine got torn and leaked water from both side, flooding the boot during heavy rain.
Yeah new parts. Give one of the parts shops (Bavarian Auto, First Division, Inner Power, Bomin Auto) a call to get the current price. Price can vary a lot sometimes, so give a few a call.
If the tear is small, you might be able to fix it by just sealing the torn section with either black silicon sealant or using closed cell foam (similar to the ones used for sound dampening). I did that for mine since the section was quite small and it doesn't leak.
Front lower arm (halfcut) with new bushes and ball joints: RM290 (L&R)
Labour: RM80 + free alignment
Front wheel bearing RM210/piece
Rear wheel bearing RM110/piece
labor to change front and rear wheel bearing = RM350
Total = RM990
Bayernz Motowerkz Bukit Mertajam, Penang
guys, can u plz help me?
my throttle paddle broke already.
where can i get the new 1? n price?
thanks...:top:
I got mine from Inner Power. Can't remember price, but it won't make you poor.
TQ bro mizhan for ur help... me bought d new 1 at inner power...:burnout:
Clutch master cylinder - RM136
Clutch slave cylinder - RM65
Replace and bleed clutch/brake fluid, install new parts + cost for fluid - RM180
Also bought some spares for use soon when service is due:
Oil filter - RM16
Fuel filter - RM37
Timing belt - RM44
Oil filter - RM16
Fuel filter - RM37
Timing belt - RM44
May I know where you bought those parts? Last time I bought an oil filter for RM38 and timing belt for RM145.
From Bavarian Auto at Jalan Segambut. I should point out that the oil filter was a OEM Mahle and the timing belt was a Contitech one. The "original BMW" version can be more expensive. I've bought the original timing belt (supposedly better quality) at RM210 before. I see most people are fine on the Contitech tho, so this time didn't bother with such an expensive belt. :p
