Haaa the list goes on...thanks TJ:top:
teejay;308454 said:6. Hella original smoked headlights.....
Rastabimmer;308467 said:Can u discribe what's mean by smoked lamp??? It's same if we tinted our headlight?? What's diff from OEM headlight???.............
miepower;308521 said:Haaa the list goes on...thanks TJ:top:
teejay;308826 said:you cannot tint your headlamps unless you lve in an area where there are bright lights all the way, anyways, JPJ will stop you one day ,then you will be in alot of trouble
smoked lamps means, it looks darker, but light output is not affected, but slightly enhance due to the reflectonolgy techniques that Hella uses to concentrate the lumens into the projector lenses
Rastabimmer;308910 said:Owh...like that ha,thanks TJ for the info!:top:
How much cost of the smoked headlamp for e30?? It's come for all types??
teejay;308951 said:smoked lamps are NLA- no longer available, was made for the post 88 models, but the older pre88 models can use, just a simple mod on the wiring split
cost differs from seller to region, in US it was going for 400 once. i.e. rm1400 or so....., but you can find one in kl for about 800-900 or so......
miepower;309069 said:Where can I find one then TJ? hmmmm .....
zaskar;309075 said:i'm trial making a set for myself now, mie, will show when its done.
evilnickwong;309493 said:The last time I saw brand new smoked Hellas was at calvintan's place, about a year plus back. Somewhere in the region of rm1.6k or something I believe.
supafly;312882 said:from what ive been told, Hella will reproduce the smoked headlamp for e30 should be available by end of this month. will cost around USD400, but i dont know the availbality in malaysia
