Coolant Issues
zulkifli
My E46 M43, coolant level is OK but the low level indicator pop-up after every 2 weeks after bleeding. What is the real problem dear all sifu?
better go to the workshop for computer test.i did mine yesterday.
3weeks ago i did top up my coolant n later the warning sign come out again.found out that my radiator hose already crack(hairline)..IINM will cost rm 300-400 too change both hose.
Hi bro ,just want to ask did your temp gone max hot , if yes please check your silinder compresion and check that your silinder gasket is still good , also check your expansion tank very common to crack. all the best take your time to check.
Already replace the rear connector attached to cylinder head, RM 60 .....problem gone
