for your info, the later model M43 comes with electric fan... and yes, it will free up some horses due to parasitic drag.... if you're itchy backside and have year end bonus to splash, do it... but if can tahan the itch, can wait till the fan clutch konked then do the 'upgrade'...cikupat;589271 said:Hi guys,
I'm new and mine is m43 + the radiator cooled with clutch fan. Got a recommendation from one of foreman to change to electric fan cause it will less burden to the engine...
What say you ? Any recommendation ?
Thank you
machinehead;589288 said:Cikupat,
I have a spare electric fan for sale.Call me if u are interested o19 2138525 RM350.00
ALBundy;589407 said:Rahizwan, there is a brand called Vaio (if I remember correctly) that do make electric fans for the M54 and less than RM900, ori BMW is close to 1400 I think. However when you retrofit into your M52, you will only get 3 speed function, instead of 7 (I think).![]()
ALBundy;591484 said:Once u convert to electric fan, you wont need the secondary or auxiliary fan (air cond fan). The electric fan would run using the supply from there.
E39 can use M54 electric fan. It makes a noticeable difference as there is less parasitic loss, especially when you are accelerating.
Cheers
cyclone9;591510 said:How to see if the fan is clutch or electric?
