Bro so coincidentally similar leaking at the same area happen to your radiator too. May i know how much the cost you spend to replaced a new unit of this radiator.kw930 said:My car having the similar leakage at the same area, but too bad there's no replacement cover sold separately.
So, end up had changed the whole radiator.
BTW, I don't think there's any glue or patch can seal it up, especially your leakage is quite severe.
Bro..thanks for the feed backYours Faithfully (YF) said:I do not think its possible for the following reasons :
1. The radiator is always hot. The glue cannot withstand the immense heat.
2. The glue will not be able to withstand the pressure.
Just my common sense but I could be dead wrong.
Bro.. thanks for advice and i know which Araldite adhesive you are telling about.Insured By Mafia said:I dont think so cap gajah can withstand the high pressured radiator..
Instead, try Araldite..a pack of Araldite comes with one tube of adhesive and one tube of hardener.
Water resistant, quick drying and super strong..basically bonds hard plastics instantly..
You can easily get it from any hardware shops...
Google it for the images..At least you will know how it looks..
Bro.. thanks for the feed back and advice.moots said:radiator leak patch up job on any plastic parts on the radiator WILL NOT do!period.
yes it may last a few days or maybe even weeks but it will eventually fail at the most awkward of time and place.
change it and have peace of mind.
Yes.. boss thanks for you advice.Herbert said:Alex,
Go and get a new radiator......this type of glue repair won't last.
Thanks sifu for the advice on ABS welding, but i don't think so KK have this kind of ABS welding.jarance said:No it will not work. you need to do ABS welding to repair the crack.
best is to buy new radiator.
Thanks for the advice bro.tckhor said:In general, the plastic has weakened. Even if you patch up one area, other areas will start to leak/crack. As fellow forummers have said, it is advisable to install a new radiator.
Yupe.. here the interesting link : https://www.youtube.com/watch?v=1rc7_BEcTtkMel279 said:Yes it can be patched up, drain the radiator and getthose glue special made to patch up radiator but this just for temporary measure as a good used or new
radiator would be much better option.
Did survey in few radiator workshop here in Kota Kinabalu, and none of them want to repair for me since they didn't repair before which i guess.Insured By Mafia said:Alex bro, you'd probably be the 1st to try that product out.
Don't think so others here can give their point of view since many opt to change to a new radiator instead.
So, update us where you found it and how much it costs.
It can help those who cant afford for a new radiator at a crucial time.
Bro that's the problem make me to think twice, either replace a whole brand new unit for the sack of peace of mind or replace this plastic cover without any warranty from the supplier just to save some money lol... any where thanks for the good infos.jarance said:To remove the plastic material would be quite difficult as the aluminium holder is machine clamped on the plastic material.
You may have to bend back the aluminium art of the radiator and then have to crimped it back again.
As far as I know, aluminium dont allow much bending. maybe one or two time. they tend to break after
a few bending process.
Great that you have found a replacement cover, I wish I found it too when I want to replace mine last time so that I can save my radiator. Mind to share how much you bought the cover?Alex5522 said:Since the leaking was not so serious so trying to survey around the radiator repairing workshop and manage to find this plastic cover as pic show below:-
It was made from China and it can save quite a lot of money. The problem was not sure about the quality.
Did any one change this plastic cover before and don't mind to share the quality and result ?
Thanks.
(sorry forgot to snap a pic of this plastic cover from the radiator workshop)
