Vanquish
- Joined
- Dec 7, 2004
- Messages
- 2,117
- Points
- 0
Originally posted by affan66@Jan 10 2006, 12:26 PM
puzzling but seriously off topic.
How come something that is already lost, signal-wise, reappears after going through valve processing.
Isn't this similar to having an EQ to boost up certain frequencies?
I was also stumped at first but if you look at WJ's post, the signal route is something like this - Valve CD player > 24 bit/ch D/A > Valve unit > Valve pre-amp > audiophile CD recorder 1:1 speed all the way. There's no mention of any form of EQ'ing going on and I'm quite sure the pre-amp used is also of a bare-bone version with no or minimal tone control.
The valve purists have argued for years that any decent valve output stage has better resolution, transperency and more "soul" than the best of what MOSFET can throw at it. In fact, in May 1973, the prestigious Journal of the Audio Engineering Society of New York (AES) published the most definitive study ever undertaken regarding the sound quality of vacuum tube equipment: Tubes vs. Transistors - Is There An Audible Difference? -By Russell O. Hamm.
After critical subjective and in-depth technical analysis, these two essential areas defining vacuum tube sound were disclosed:
1) "Our extensive checking indicated...a definite audible difference in the sound quality...where there is a mechanical-electrical interface." "...power amplifiers driving speakers..."
2) "The basic cause of the difference in tube and transistor sound is the weighting of harmonic distortion components in the amplifier's overload region."
Not suprisingly, during a recent listening session in a friend's car who has 2 TBD Butler Tube amps and a tube output Pre-amp, I realised that the level of details produced by these amps are just staggering as I started hearing of notes and things that I did not even hear from the same disc in other non valve powered systems.
