Any recommend Voltage Stabilize for E36...?
lemonteastudio
Hi There,Since the VS is highly recommended for almost 15yrs old E36, is there Any brand of VS recommended from the member..?
BMW alternator comes with voltage regulator, just have it replaced and you are as good as new. Google about the faults caused by faulty regulator and you can identify the symptoms http://www.youtube.com/watch?v=cno3vBj2_so
No. Description Supplement Qty From Up To Part Number Price Notes Photo
01 Pulley alternator DB=49MM 1 12317552352 $92.35
02 Voltage regulator 1 04/2002 12317512163 ENDED
only applies to
-- COMPACT ALTERNATOR 90A ? 04/2002 12317512151 ENDED
-- AT-COMPACT ALTERNATOR 90A ? 04/2002 12317512162 ENDED
-- COMPACT ALTERNATOR 90A ? 04/2002 12317516098
-- AT-COMPACT ALTERNATOR 90A ? 04/2002 12317516100
03 Cap 1 12317505923
04 Hex bolt with washer M8X85-Z1-ZNS 3 03/2004 07119901575 ENDED
04 Hex bolt with washer M8X85-U1-8.8 3 07119906141 $1.89
05 Cap nut 1 12427565287 $3.23
Hi anaksarawak & lemonteastudio,
Does the alternator can be serviced?. How much for new alternator estimately?
It sound like below vid:
http://www.youtube.com/watch?v=6pUmAaD183o
Mech told its due to alternator, i need to clarify with another mech.
Sorry lemonteastudio to hijack your thread.
BR/
what are the symtom if voltage ragulator going to kaput? and how to identify?
Unstable idle, light dim as voltage dropped, engine can't maintain a smooth cruise
I am not sure where to find the replacement regulator beside chop shop, Bavarian auto said they need to order and can't quote me yet
The VS i mean here is....
Pivot Voltage Stabilizer + Supplementary Earth = Superior Results
For the ultimate in electrical efficiency, Raizin brings you not only superior electrical efficiency and voltage stabilization, but with our original circuitry design and special noise reduction condenser you can enjoy diminished noise and lessened high-frequency impedence.
• Increases Torque at Low and Middle Speeds
• Stabilizes Idling and Improves Engine Kick-Over
• Improves Engine Response
• Increases Headlight Brightness
• Improved Fuel Economy
• Improved Battery Life
• Improves Audio Quality
I bought it off a guy who sells his homemade VS on lowyat.net. Might have given me slightly better fuel consumption, but could be also be attributed to a slight change in route on my daily commute. Then I changed my VANOS seals and my fuel consumption improved further. Mine's a manual so I can't comment on the improvement in automatic gearshifts. Other effects aren't apparent to me.
Good info bro... this what i hope to hear & share from the member... hope more member share the brand and the review after install the VS here...
im my view these after market VS things are like the other things that you put in the petrol tank to 'align molecules' for increased MPG etc, just a gimmick----- if your alternator is in good nick, and your earths are clean and tight you will get all the benefits as described for the after market VS !--------- apart from 'increasing torque' that is !!
Alternator - new and old
Just a few days back, I was enquiring at a PJ stockist: E36 new alternator is like RM1,100, while a recond unit goes for RM380.
Call Master Alternator at SEA Park, PJ at 03-7876 2223.
Is it near KFC there ? I have changed e36 alternator which very near the KFC Sea Park. After installed the recond alternator around 1 week. I found out that the alternator not enough charge. The boss of the shop refused to change it and keeps on said the alternator is working fine. After 1 month the alternator is dead then i asked him to change but he dosent wants to change it.
