Devillian;807280 said:Just be wary for the headers... quite a few of them aren't designed properly for performance. They will give you a good sound but you would actually lose power.
Headers should only be upgraded when you vehicle goes past a certain threshold of air flow. If you consider supercharged engine running 7-10PSI boost still recommend the stock headers, it gives you a benchmark of how much more air you need to be flowing before the headers actually start to be useful.
B33mEr;807321 said:Not sure for FI but headers do makes a difference for NA. As you know M54 engine the cats is at the header near the exhaust port, that itself restrict the exhaust flow. Plenty of dyno sheets to prove that at e46fanatics.
krsna86;807325 said:Bro, would DeCat solve this restriction issue?
B33mEr;807332 said:If you mean taking out the cats at the manifold yes but then you have to remap to take out the check engine light and a tune to optimise the mods.
The correct approach would be getting the a proper exhaust manifold like these guys are making - http://www.motorsportsdownunder.com/catalog/i41.html They even make a turbo manifold :4:
But it is expensive since not many company is willing to make rhd manifold for the M54 ... whether you can justify the cost is up to you really.
P/s: i know one guy that installed headers from motorsports Downunder for his 523i M52 engine ... From what i can tell he loves it and there is no issue. Admittedly M54 is a more complex system specially with the DME.
anaksarawak;807335 said:Bro nice sharing, any cat on N42/46 engine???
aidilj;807340 said:Yes, delete it!
wingzee;807348 said:Since we're on the topic of headers and cats, would deleting the car actually affects the FC in any way?
anaksarawak;807386 said:WOW!! Delete it and code to clear the error code will help to gain more power? Wont the car be running rich and FC be very high?
aidilj;807409 said:This is then how the exhaust failed on me, too much restriction by the muffler?
aidilj;807401 said:I didn't experience any adverse effect with fuel consumption after deleting the cat
Surprisingly Bro, there was no error light or code with deletion of cat on my machine. The post cat sensor is the one which shouldve make sure its function is still good. Cat is to burn unburn fuel during combustion and convert contaminant to environmental friendly one before letting it go out of exhaust. Deleting the cat wont make your car run rich
Devillian;807413 said:That would have been sheared off from stress rather than from "air flow restriction". Was that section welded on or a one-piece cast?
krsna86;807415 said:Bro, did you DeCat and put a bullet there or just sambung additional piping?
aidilj;807420 said:Bro' I've told them to throw that portion out and put a pipe, but due to the fact that O2 sensor bung is mounted on the cat portion they just operated the portion out and seal back.
By the way, N42 pre 2003 march and post 2003 march has different cat and O2 sensors configuration
