adjustable suspension
evisuzuki82
hi bro....i currently running on eibach prokit spring to lowered my car...but still need to lowered a little bit....juz wondering how much the cost for adjustable suspension??new or used??where can i get it??or do anyone have adjustable absorber for e46 325ci??please pm me....cheers
correct me if i m wrong
the shockie n coil for 2 door n 4 door should be diff.
cos body weight diff.
just like ur eibach for 4 potter n 6 potter
evisuzuki, I got mine for RM2.4k brand new. However only the front is height adjustable, the rear is still using independant suspension (ie. absorber and spring are seperate).
me recently bought eibach pro kit for e30 m40, but from the box theres nothing indicated it was for 4 potter or 6 potter, but the towkey insist that it was for 4 potter...how i might know?? btw it stand a little bit higher..(manual scale....3 jari :blush: ) One more thing, how will we know either it is original germany, taiwan/japan spec or a fake one?? hope somebody will help
emmm, only eibach spring...
y dun give a try on absorbers upgrade...
bilstein...H&R...
if you want adjustable, why dun try Hot Bits...
Originally posted by leakwoon@Apr 19 2006, 03:42 PM
titan good ar?
want to know... i can let you test my car
TITAN Fully Adjustables
but, must belanja makan :nyehehe: :nyehehe:
aduusss....actually,i dont have any budget but need to force to buy as my car really high now......about 3 finger....i'm thinking of adjustable but it must be a set...if front only...how about the back?
leakwon...fyi,i put eibach pro kit from 325 saloon...actually it just the same one...correct me if i'm wrong....
oh yaa....anymore option??anybody else that might have adjustable?4 piece?
evisuzuki82,
if all you want is to lower your car, don't waste your money buying adjustables. Just get some lower lowering springs.
Even if you do get adjustables, just get the height adjustables, don't get the rebound/damping adjustable ones; after all, all you're after is the "look", right?
The ride height of a stock Ci is SLIGHTLY lower than a sedan, so if you put in a lowering spring from a sedan, there will probably be not as much lowering effect compared to on the sedan
Look for 60mm or 70mm lowering springs from Eibach or OMP. Cheaper than height adjustable kits (circa RM6,000 and upwards???).
guys.....for ur info...eibach pro-kit lowered my car about 1/2-1 finger gap....then,i did a widebody to my car...after the conversion,the height of my car increase nearly 3 finger gap even though eibach has already install....my question is....
1. what kind of spring that can lower my car,if it possible to
lowered 3-4 finger gap from stock??
2. or is it compulsary to lowered my car using adjustable??
3. if i lowered my car(from stock)to 3 finger gap,will it touch a
ground???
i'm using 225/40/18 and 255/35/18....please give me some guideline...thanks in advance....
leakwon..it is different story lor...if i dun do widebody...it lower nicely....no need to worry...my case is different as i change the panel....
