fast&furious
- Aug 12, 2005
- 35
Yesterday my windscreen washer tank lights up, so as usual I just refill it but the light comes up again after 6 hours later. Hmmm I suspect either the tank or the rubber hose has a leakage.Then I called a few workshop and was quoted from RM300 - RM400 to have the washer pump replaced excluding labour. The washer pump is working fine and the washer tank has no leakage neither does the rubber hose is faulty but the workshop insist on replacing the whole unit.So the only problem must be the rubber seal between the pump and the tank which looks worn. So I went internet shopping and found the spare part called 'washer pump grommet'. I manage to source it out locally and DIY today.http://img100.imageshack.us/img100/4386/016qg.jpg1. Location of the windscreen washer tank for E46http://img218.imageshack.us/img218/3940/024ol.jpg2. Removing the nut fastening the washer tankhttp://img218.imageshack.us/img218/50/033ck.jpg3. Twist and remove the water level sensorhttp://img100.imageshack.us/img100/9531/047jy.jpg4. Water Level Sensorhttp://img218.imageshack.us/img218/4650/052hv.jpg5. Remove the washer pump from the tank by pulling it outhttp://img100.imageshack.us/img100/9342/060sv.jpg6. Washer Pumphttp://img218.imageshack.us/img218/3526/075gl.jpg7. Worn grommet due to wear and tearhttp://img218.imageshack.us/img218/4526/081cy.jpg8. Remove the grommet and clean the washer tankhttp://img218.imageshack.us/img218/8229/094ph.jpg9. Brand new washer pump grommethttp://img218.imageshack.us/img218/379/108vu.jpg10. Just plug it in. Should be a tight fit.http://img218.imageshack.us/img218/4539/116kw.jpg11. Reinstall all the fittings back in order.Final testing 100% good and no more leakage or warning lights. The final cost is:Washer pump grommet : RM13.00Labour cost : FreeChecking Fee : FreeTotal In Saving : above RM400Satisfaction : Priceless........Fast & Furious
