5 Series
G30
tyre brand
<blockquote data-quote="Davidkeyla" data-source="post: 756970" data-attributes="member: 64806"><p>Can you share more information about the type of car you are driving, which BMW is it?</p><p>As far as I know, Continental's OE tires are designed specifically for the BMW. Whether it's winter tires for the cold season or summer tires for scorching heat and wet roads. You should consider run-flat tires for BMW, it is the most suitable tires, you can refer to this article <a href="https://tireer.com/best-run-flat-tires/" target="_blank">https://tireer.com/best-run-flat-tires/</a></p></blockquote><p></p>
[QUOTE="Davidkeyla, post: 756970, member: 64806"] Can you share more information about the type of car you are driving, which BMW is it? As far as I know, Continental's OE tires are designed specifically for the BMW. Whether it's winter tires for the cold season or summer tires for scorching heat and wet roads. You should consider run-flat tires for BMW, it is the most suitable tires, you can refer to this article [URL]https://tireer.com/best-run-flat-tires/[/URL] [/QUOTE]
5 Series
G30
tyre brand
