Suspension issues
vman
hi,got any advise on selection on new rear top mount set ?? yesterday mine kaput after going a thru a nasty lubang jalanan !!! after the pothole, straight away rattling noise on the left hand side. opened the boot liner and found my top absorber was inside the booth. so the checking seem the top mount gave way.any recommendations on replacing a new unit ?? OEM / aftermarket / custom ??found this also from the forum:http://www.bmwclubmalaysia.com/forums/showthread.php?32469-FS-Rear-top-mount-reinforcement-for-E36-46-Z3http://www.bmwclubmalaysia.com/forums/showthread.php?43737-Rear-top-mount-reinforcement-plates-for-E36-46-Z3/page2roughly $ cost of OEM top mount ?? anything else i need to check and change together with this repair.thanx guyse36 - 1994 325(A)
I don't know if the local parts stockist stock them, but z3 has the reinforcement plates from the factory. If you do some digging you might be able to find the part number and bring it to a BMW stockist. Then you can just use the stock rear shock mounts along with the z3 reinforcement plates.
called in AB and got a quote for approx rm20 each. so per set should be below rm50.
bro 26,
will look for z3 reinforcement plate and ask them tomoro when i send in the car. thanx for the info
