David Yong;220300 said:It could be active steering malfunction. Suggest u send in it into AB to check it ASAP.
SUBJECT
ELV Warning in Instrument Cluster
MODEL
E90, E91, E92 (3 Series)
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
The ELV (Electronic Steering Lock) check control warning illuminates in the instrument cluster and in some cases, engine start is inhibited. Diagnostics reveals fault code A0AA in the CAS (Car Access System) and prompts a control unit replacement.
CAUSE
Low voltages in the vehicle electrical system when cranking/starting the engine.
PROCEDURE
This problem has been integrated into DIS diagnostics. Follow diagnostics and relevant test plan using DIS V49.0 or later.![]()
SI B32 07 06
Steering and Wheel Alignment April 2006
Technical Service
SUBJECT
Steering Column Clicking Noise
MODEL
E90 (3 Series) and E91 (3 Series Sports Wagon) produced up to 11/05
SITUATION
Customer may complain of a slight clicking noise heard, mostly at slow speed, when turning the steering wheel at about 180 degrees.
CAUSE
Steering column manufacturing tolerances stack up.
CORRECTION
In case of a customer complaint, replace the steering column only. Do not replace the steering gear and the steering spindle (lower joint assembly).
The steering column manufacturing process has been improved in 11/05.
PROCEDURE
Replace the steering column per Repair Instructions RA 32 31 090.
Perform steering angle sensor adjustment/calibration per Repair Instructions RA 61 31 996.
PARTS INFORMATION
Part Number............... Description..............Quantity
32 30 6 772 273.........Steering Column.......1
WARRANTY INFORMATION
For information only
Schwepps;220413 said:Check under the dash for a puppy? Sorry, sorry, kidding, kidding, can't resist!![]()
325xi;232805 said:Hi,
Just FYI.
I had the same problem with the steering lock sign (orange color), this was fixed yesterday (July 18, 07) under warranty.
According to the technician he replaced the steering column.
a|an;220297 said:Dear guys,
My E90 been acting weird latelty. When I insert my key, a steering lock sign will appear, sometimes in yellow, sometimes in red. Usually when that happens I wont be able to start the car. Whats happening?
