Starting problem
Ibrahim Hanif
Dear all,Today I encounter a probleh which my e46 2002 n42 wont start quite a few times. Sometimes it easily start and sometime have to try 3-4 times. My battery just changed a year before. Light all bright. What is the culprit all sifus. Is the starter or anything else. How much does the starter cost?. Really need advice. I'm going outstation more frequent and afraid i would stranded in future travel.Thanks
Ibrahim Hanif;729216 said:
Dear all,
Thanks
Hi ibrahim
I have same issue but dunno whether same with u or not.Car can crank (not battery issue) but macam tersekat nak start. I already change fuel filter, replace camshaft sensor and repair valve cover gasket(due to leaking at spark plug) but still hard to start. Sometimes need to press the pedal when to start. Is it same with u?
My advise, ask your mechanic to run a diagnostic test. Pay special attention to the crank sensor. This could be the culprit.
Hi eri,
As what my mechanic said, it's the starter. It's the common prob for e46. I tried so many times then only can start. No need to press pedal. Sometimes I heard a the grrrrrrr sound at the center of dashboard.
eri;729343 said:
Hi ibrahim
Dear Vincent,
I noticed the if the crank sensor the the culprit, the car totally cannot run right.
By the way, what do you mean the car can crank eri?. Just for me to get clear. Thanks
eri;729343 said:
Hi ibrahim
Bro Ibrahim Hanif, crank means the sound of the starter motor turning to start the engine. In this case, Bro eri means the starter motor is running but no ignition.
Bro Aidil
Mine when start no crank. So, means that my starter motor is the faulty right?. Am i right bro?
Bro Ibrahim Hanif,
I would second Bro Vincent take on crank sensor as it is a sensor and maybe a sign of failing sensor.
I would also like to view it from the drive away protection system. As there would be a lot of checks be done before the starter can even execute. Read here : http://www.computersolutions.cn/blog/wp-content/uploads/2011/02/BMW_EWS.pdf
The mechanic would check if there is even power to the starter before doing anything else.
Cheers
Ibrahim Hanif;729633 said:
No bro. When drive as usual. After stop shut off engine, start again, many times to try. Might be the starter is it?. No crank sound when start.
So yours would be better described as warm start problem? No problem starting when cold? It could be still the sensors (cam/crank), plug in your diagnostic machine Bro.
This morning i haven't try to start the car bro. How to know either the starter or crankshaft sensor is the faulty.
May be you can try to ask your mechanic to check your starter carbon brush.
Sometime, if no crank when you turn the igniton key, it could be due to:-
1. EWS and DME not sync properly - either key is faulty or EWS is faulty
2. battery very weak - check terminal for loose connection at battery.
If got crank but cannot start, it could be due to:-
1. battery weak
2. fuel pump faulty or about to fail
3. crankshaft about to fail
Hi jarance,
mine can crank but after hidup 2,3 second then engine die.need to try 3,4 times to start again. after can start, need to press the pedal and after that is ok. if dont press pedal, car like motorboat.is it fuel pump or ignition coil?
1. battery weak
eri;729662 said:
Hi jarance,
your problem is most likely due to the leaking vacuum hoses.
or fuel filter is chocked.
Fuel filter already change to new last week and already check with mech,no leaking at vacuum hoses. Run GT-1, no faulty come out.why ar?Sorry ibrahim Hanif, borrow your tread.
Bro Jarance,
What is EWS & DME?, I read some of the info on the net which is about the immobilizer. Does it caused by my key program?. My key works just fine, lock and unlock got no problem.
1. battery weak
