Reliable Silicon Wiper for E39?
jsng
Hi sifus ...Need some advise ...Did any of you use any third party wiper rather than the ori BMW wiper? Any reliable brand that offer good and durable silicon wiper for E39?My current wiper is not performing well and it will easily drop off (the wiper blade) when i leave the wiper arm, not sure whether some clips are spoilt ..Thanks ..Regards,JS
I am using Dura Edge silicon wiper for 3 years now without any problem. Price about RM 80.00 for a pair.
Hi Herbert,
where can i get a pair of Dura Edge silicon wiper?>
thanks in advance
For Dura Edge silicon wiper, their office tel no is (03) 7805-4001. They will remove your old blades and install new silicon blades.
Dura Edge is a good brand....have used it on my previous rides....
d other brand that u can consider is PIAA....if d wiper blade frame KOed....u can buy d normal bosch wipers for e39 first
use them for awhile until d blade kaput....
then consider changing to Dura Edge or PIAA silicon blades....use back d blade frame...kau tim...
Hi JSNG,
I am using PIAA silicone wiper blades really good, i fixed mine at uptown KK mobile assesory shop. U need to be careful that your current wiper the clips still in good condition so that the silicone blades will hold up.
Cheers,
PIAA might not hv the desired length thus hv to cut to shorten.
excellent but kinda expensive.
paid around 140 for a pair, just the blades only.
but definitely worth it.
BOSCH hv fakes out there.
a workshop in jb wanted to charge me $160 for bosch ones. Is that normal? or rip off price?
I got my Bosch model 539 (for E39) from a spare parts shop here in Butterworth for RM90 a pair. A cheaper option is to buy Dura-edge wipers from Tesco and rip the silicon blades out and replace it on your old wiper frames.
Thanks all for the fast response :)
I think i might give the Dura Edge a try ... remembered that my wife used this before in her x-trail and its pretty reliable ..
BTW .. any idea on which shop i can get the Dura Edge?
As for the PIAA, is it more durable the the Dura Edge?
Thanks ..
Regards,
JS
Thanks ..
Regards,
JS
The telephone number above is Dura Edge Malaysia. If you are in PJ, just call them and go directly to their office and they will install the wiper blades for you.
I see ..
Thanks Herbert .. will give them a call once i am back from trip ..
Appreciate that :)
Brother,,,i did cal the above num,,they claim,,they already stop the service of replacing the blades at site...they can only advice the availability of the blades at stores new to us,,like for me,,will be eneous kepong JJ
pm me if you need the dura edge for your e39 , i can install for you as well , rm 70 including installation .
to use dura edge wiper make sure your car winscreen is free from any kind of wax or rainx , it will make your wiper judder when the wax near to end of life .
i can do group buy also if you guys are intrested .
Where are you based?
I'm using a Bosch blades now, used for 2 years already. Might be time to change the blade, when light rains the blade judders and make some noisy sound.
Mine also desperately need to be changed. Feels like rubbing the ws with a sand paper whenever it turns on. Can I get your contact details bro?
Sent from my LT26i using Tapatalk
3 things can happen when wiper judder ,
1 . The rain x or the was you applied must reapply
2. Wiper blade misalign , Ned to be adjusted .
3 . Wiper harden, usually does and have to change .
I'm based in kl near sunway Giza area. My contact is 0122290635
Group Purchase? :p
My wiper is experiencing the the same judder issue .. but i didnt use any rain-x .. perhaps it could be due to the miss-alignment issue? or wiper aging issue?
if you guys need help on wiper matter i can help out, not necessarily have to get the dura edge wiper . if you guys need it then you guys can set a date and time and meet up at somewhere near kota damansara giza area have a small tt somewhere bright and bring some water with you all to try out the wiper after adjusted .
Brother Vincent,
I'l be back end of month,,,will pm you for the replacement of the viper blades,so far is there any arrangement for any a group buy?.
