Petronas Synthium Ad
OSFlanker
Any of you guys notice the Petronas Synthium advertisement in the newspaper? Look carefully at the engine the ad features..........got Vanos cover one!
*Hijack*
The Cumpany previously I worked with supplied the DCS - Distributed Cuntrol System - to the Melaka Lube Blending Plant!
:D
The Mach 5 is local blend and bottled and packed... the Syntium is imported blend, locally bottled and packed.
:rolleyes:
*Unhijacked*
:ph34r:
I tried the Syntium but the oil quite evaporative.... oil go 'missing' at alarming rate... and engine not as smooth...
:eek:k:
How fast the engine oli got evaporated. I have experienced that 10,000 KM engine oil almost reached to lower level.
I beleived fully sythentic should be better right
Talking about lubricant oil, I have a problem with Shell for my previous car.
There is some sabotage happen in shell. The lubricant oil i receive is in purple colour. And the viscosity of the oil at 100C is out of specification. The lubricant are send to Shell Malaysia for analysis and Shell Malaysia did another detail investigation in UK. There still no result till now. Is about 6 month gone and I still waiting for the result.
But I'm lucky that this is not happen to my UDM. The engine noice lever increse even after a few oil change. I will make a forum and show the detail to all the members. Be carefull when oil change, check the oil before pouring in to your UDM.
After about 3000KM drive on Pet Syntium Fully synthetic engine oil, I experience oil loss at about almost 1 liter. Is normal spare part shop sell this engine oil?
