perlu flush ???? or not n42
rajin tukar minyak hitam larrr brother ..... jangan tunggu sampai 10 K ....
chaboy;826871 said:
keta baru amik bro... baru 2bln....
kalu boleh jangan flush ... try tukar minyak hitam 3 kali dalam satu bulan dulu ...pakai cap X punya ya murah murah je ...lepas 3 kali tukar, baru pakai yang mahal sikit ....
Baik.....pastu boleh hilang ke yang berkerak n yang warna coklat tu bro..
ya ...buat macam iceman suggestion....pakai mineral oil 20w50.
pas tu tukar synthetic.minyak synthetic ada cleaning properties.
hopefully over time the varnish akan cleanout by itself.
kalau kete x ada pobrem....x perlu flush
chaboy;826864 said:
salam.....
apa nak buat engine mcm ni....
ada cadangan x.... pitam ni...:rock:
This is normal bro not to worry much...
Bro keta tahun bila...
Buat mcm bro iceman ckp tu...
Pakai mnyak 20w50 pastu tukar dlm 1000km je...
Buat 2 kali lepas tu baru tukar mnyak grade semi tu...dlm 5000 je tukar...
Nak flush bkn tak blh cuma risau oil seal n 0 ring mungkin dah keras...
Nanti akan berlaku kebocuran(leaking)...
Selamat mencuba dan jgn terlalu riasu sgt...:rock:
yeah.. pernah dengar
chemical yg digunakan mmg cuci bersih kerak, tapi seal/o ring pon skali rosak
my 0.325i sen hehe
pening.... keta tahun 2003 reg 2008 dan ter bernah digunakan di jalan raya malaysia...
cuma baru 2month diatas jalan raya malaysia start i beli.....
Check out this thread too...
http://www.bmwclubmalaysia.com/foru...e-and-one-can-get-f*cked&highlight=oil+return
Do more frequent oil change with mineral or semi syn engine oil... between 2,000-3,000km interval... Let the sludge dissolved itself with each new oil change...
Some engine oil flush are harmful to the rubber and plastic bits in the engine. Just drive normally. long distance drives (at speed limit) even better as the engine is running at optimal temperature and at constant speed.
At most important of all, don't go beyond 10,000km between oil service even with fully syn oil...
was thinking to do engine flush too...been survey around the internet including oversea's beemer forum....majority discourage to do this...
