ess530i;327649 said:i am also having some prob on my ignition which is apparently caused by my denso iridium plugs. searched the forum and think i will go for beru-x to see if there are any improvements
ess530i;328519 said:omg leforte you are my lifesaver... i am experiencing some shudder at mid-high rpms...could be leak at the manifold but my mechanic told me he used the sealant according to the instructions. so i will try to resolve the ignition issue first. will revert to my denso iridiums but with closer gap as u recommend. as for grounding, should i install aftermarket grounding systems? what about okada project plasma coils? thanks a bunch especially on the beru-x advise
leforte;328528 said:check on your leak first. did your mech retorque the bolts holding the manifold after the sealant has cured? if he didnt, it may be leaking only at mid rev when the boost comes in. have him double check on the bolts and retorque if required. as for the tuning, just call hans /absjorn on the phone anytime. they have the best aftersales service around.period....
anyway, i know someone with a ts2 had a similar mid rev shuttering, it was due to a malfitted manifold, he refitted the whole kit with new gasket and plenty of sealant and it was ok after that.
as for your ground strap, just have your mech take it out and remove any rust and sandpaper the contact point for a clean fit. FORGET about those grounding kits, pure gimicks... oh.. there is a grounding points on the main ignition harness, do make sure they are well connected too.
the okada coils will work fine. IMHO its just way too pricey for a small gain. have all your coils resistance check, replace any one that has a different rating, if they are all ok then ask CALVIN if he can get you the Okada Plasma Direct instead. its a add on booster cap to your ignition coils and it works the same way as the plasma would but its much cheaper and from the same company.
leforte;328590 said:you should be having a 7psi kit for your automatic 530i. so 0.45bar should be close to the target psi. your -0.7bar idle pressure seems ok, check on the pre compressor throttle body connection, probably a slight leak there. the surge/jerkiness might be due to sudden lean AFR that causes a pull in timing. btw, did you replace the fuel filter?
If no leaks were found? go on to trouble shot the ignition side. try changing a new set of plugs, just use the oem copper or platinum ones. next, clean the MAf or if you can borrow another MAF from a working car, try it on. If none of the above is abnormal and no error codes shown, then I suspect incorrect cam timing and realignment of the cams is the next step.
ess530i;328769 said:replaced my volker plugs today with nology silver & my stock ignition coils with okada project plasma direct. result is noticeably better & smoother acceleration and boost increased from 4.5 to 5.5bar (8psi) with better fuel economy but the jerkiness during full throttle is still there. my final suspect is the tuning done by ess which may not be suitable for our weather. there may be too much fuel as indicated by the additional carbon deposit on my exhaust tip. i did replace my fuel pump and filters during installation of the supercharger. my kit included larger injectors which i am contemplating to change back to the originals to reduce fuel. any comment?
adliz;328889 said:so, what hp is the sc pushing now? 100hp more? what bar?
shedden;328892 said:Glad that you liked the Okada Projects we installed for u, it was also nice to finally meet an E60 performance enthusiast. By today, you should get even better response from the Okada & Spark Plugs, because of the ECU self-learning capability.
As for your jerkiness, I highly suspect is the tuning, which has to be verified after doing a dyno for your car. After observing your car yesterday, I suspect it's running rich because your exhaust area is now charcoal black. Before you change the injectors back, just run a dyno first. Just my 2cents
Regards,
Shedden
ess530i;329752 said:jerking / shudder problem resolved by adding octane booster to my v-power fuel. problem is i'll be broke in no time if i continue adding octane booster in every tank. also there is warning that the catalytic converter / oxygen sensor may be damaged with frequent and heavy dose of the booster. i guess a retune would solve the problem to cater to malaysian fuel?
leforte;329792 said:adding octane booster is just a temporary fixed. the ess tuning works ok for a number of cars using even regular fuel, with only a lack of power being the only drawback when the ignition timing is pulled/reduce to counter knocking. there are many other variables that could cause knocking ie:- lean AFR, MAF failure, O2 failure ...
my first guess its highly likely there is a leak somewhere upstream of the SC which is leaking in unmetered air that will lean out your fuel mixture and the DME will just pull/reduce the timing to counter that. my second guess would be the metering system, since it requires the MAF element to be transfer to another housing, and it does not have the original grated mesh before the heating element, the MAF may not work accurately. the grated mesh is there to straighten the airflow for a precise air measurement. without it, some unmetered air might be flowing pass it. hence the knock. the jerk may be from the sudden timing pull/reduction in the event of engine knocking.
ess530i;329373 said:not yet dyno so dont know how many HP but its running at 0.6bar. i still doubt it can beat your gti...
supergripen;330219 said:if i'm not mistaken,ESS quotes all their power ratings for 96ron euro rite? dunno how that compares to ours but judging from ur experience and explanation,the fuel(or rather the octane rating) u use is probably below what ESS has tuned ur car for.having to add octane booster all the time will indeed make things kinda suck especially since we'll be paying more for fuel in a few month's time.. salvation maybe in the form of 99ron fuel that we're rumoured to get,next to 95ron for the masses that is..
then again,like leforte said,there are other ESS users here using our normal fuel and running perfectly.hmmmm...
also,noticed that u were running 0.45bars before.only after u added those plasma ignition coils and silver plugs did u get 0.55bars which is what a TS2 kit should make rite? there might be something there to ponder too.it should be running 0.55bar from the onset rite?
used to run 1.45bar on my STi.. shucks,i miss boost!!!
maybe u should email absjorn.. he'll know what to do.
good to know there are ESS users out there:top:
