junglerock
- Dec 8, 2012
- 29
I am planning to have a oil change in every 5000km, is there any work shop instead of Bmw service shop that can recommended in KL area?
splee;820200 said:In my opinion, 5k for engine oil change is overkill. Fully synthetic can last 15 to 20k.
anaksarawak;820219 said:10k is best with out the oil filter to avoid detection by sc. 20k is too long for our weather. Also do change your oil every year even if you didn't travel 10k km
Nmr Nik Soh;820398 said:i'm wondering if a car cant be done 10k per/year..better go to semi synthetic or cheap engine oil for save the money..can we
do that?
do that?
anaksarawak;820422 said:Why not bro and I believe its cheaper vs an overhaul
bro, what do u mean by normal eo? u are referring to the mineral type, arent u?Volvos525i;820223 said:Yes agreed with you bro..
While for normal engine oil yes its 5k for every oil change...:burnout:
huskar3399;820540 said:bro, what do u mean by normal eo? u are referring to the mineral type, arent u?
Volvos525i;820701 said:for normal engine that are more then 5 yrs SAE 20W50...
Val101;820705 said:...and the most important thing i do this was that i have tried allowing it to Clock 10k but on two occasions when its on 5K plus to 6K my Engine light will Blink...top up Engine Oil. So i decided to continue Changing every 5K.
_M_;820730 said:Val..:listen: u sure theres no engine oil leak?
I change every 10k without any blink.. but then again, nobody rempitz like the Black Powoar ///M535i :56:
