need advice- map setting
McFir7
recently i got myself a safc select for e36 318is.(piggy back i got from a friend here).i when to install at one of the dyno shop in penang.my mod only hiop exhaust center to backafter tune i found that the setting was like this.hi throttle is 50%lo throttle is 10%hi throttle 1000-3000 points was set to 0% (3 points)3000-7000 points was set to +10% (9 points)low throttleall 12 points was set to 0% dyno chartmy air fuel ratio before setting is 14.05 108.06hp after setting is 12.72 119.34hpthats what i got on chart.from my driving i feel power but bad consumption n not smooth.also feel that the chart is not relevant as the tuning is adding fuel.but the afr is less.can anyone please advise me on this.
i though there is number of guys here using piggyback?no one can advice me on this?
mmmm im curious.......got the same engine in my e30....people been saying about smt6...maybe you should go that direction
