3 Series
E90, E91, E92, E93
N52 engine ticking noise?
<blockquote data-quote="viewfinder" data-source="post: 18872" data-attributes="member: 1704"><p>Pls refer to this <a href="http://www.bimmerpost.com/forums/archive/index.php/t-320299.html" target="_blank">thread on US site bimmerpost.com</a>. Is it a common problem for the ones in M'sia, and if yes do you managed to get fix under warranty?September 2009This Service Information bulletin supersedes SI B11 09 07 dated January 2009.SUBJECTIntermittent Hydraulic Valve Adjuster (HVA) Noise MODELAll E82, E83, E88, E85, E86, E60, E61, E70, E90, E91, E92 and E93 vehicles with N51, N52 or N52K engines produced approximately up to November 31st 2008; refer to cylinder head casting identification attachment. SITUATIONAn occasional ticking or rattling noise from the camshaft hydraulic valve lifters (HVA) may occur during cold engine starts, due to frequent short-distance driving, or the noise may occur for an extended period of time even though the engine is at operating temperature. Improved parts were phased into production beginning on 10/1/2008 and fully implemented on November 31st 2008. CORRECTIONDo not perform the bleeding procedure that was previously provided in SI B11 09 07 which has now been deleted.All vehicles produced between 10/1/2008 and 11/31/2008 must have each vehicle's cylinder head casting number identified before hydraulic valve lifters (HVA) replacement, due to staggered implementation. Refer to the attachment for the casting number location. Vehicles produced after 11/31/2008 have already been fitted with improved parts. Vehicles produced prior to 10/1/2008 will require the new parts.Improved Casting NumbersN51 (B30)7588277.01N52 (B30)7588273.01N52K (B30)7588271.01A cylinder head casting number that does not match will require replacement of the 12 exhaust camshaft hydraulic valve lifters (HVA) as per Repair Instruction RA 11 33 050, Removing and installing/replacing all rocker arms. Only the exhaust camshaft and rocker arms have to be removed in order to replace the hydraulic valve lifters. Do not remove or replace any intake camshaft valve train components.PARTS INFORMATIONPart NumberDescriptionQuantity11 33 7 605 330Hydraulic Valve Lifter (HVA)12Refer to EPC for additional gaskets, seals and bolts, as required by the Repair Instructions.WARRANTY INFORMATIONCovered under the terms of the BMW New Vehicle Limited Warranty, or the Certified Pre-Owned program.Please refer to the latest KSD for the applicable Main or Associated labor allowance for the specific model.Defect Code:11 33 93 39 00Labor Operation:Labor Allowance<img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite8" alt=":D" title="Big Grin :D" loading="lazy" data-shortname=":D" />escription:00 58 248 Refer to KSDReplace exhaust camshaft hydraulic valve lifters (HVA)*Main Workor00 58 827Refer to KSDReplace exhaust camshaft hydraulic valve lifters (HVA)</p></blockquote><p></p>
[QUOTE="viewfinder, post: 18872, member: 1704"] Pls refer to this [URL="http://www.bimmerpost.com/forums/archive/index.php/t-320299.html"]thread on US site bimmerpost.com[/URL]. Is it a common problem for the ones in M'sia, and if yes do you managed to get fix under warranty?September 2009This Service Information bulletin supersedes SI B11 09 07 dated January 2009.SUBJECTIntermittent Hydraulic Valve Adjuster (HVA) Noise MODELAll E82, E83, E88, E85, E86, E60, E61, E70, E90, E91, E92 and E93 vehicles with N51, N52 or N52K engines produced approximately up to November 31st 2008; refer to cylinder head casting identification attachment. SITUATIONAn occasional ticking or rattling noise from the camshaft hydraulic valve lifters (HVA) may occur during cold engine starts, due to frequent short-distance driving, or the noise may occur for an extended period of time even though the engine is at operating temperature. Improved parts were phased into production beginning on 10/1/2008 and fully implemented on November 31st 2008. CORRECTIONDo not perform the bleeding procedure that was previously provided in SI B11 09 07 which has now been deleted.All vehicles produced between 10/1/2008 and 11/31/2008 must have each vehicle's cylinder head casting number identified before hydraulic valve lifters (HVA) replacement, due to staggered implementation. Refer to the attachment for the casting number location. Vehicles produced after 11/31/2008 have already been fitted with improved parts. Vehicles produced prior to 10/1/2008 will require the new parts.Improved Casting NumbersN51 (B30)7588277.01N52 (B30)7588273.01N52K (B30)7588271.01A cylinder head casting number that does not match will require replacement of the 12 exhaust camshaft hydraulic valve lifters (HVA) as per Repair Instruction RA 11 33 050, Removing and installing/replacing all rocker arms. Only the exhaust camshaft and rocker arms have to be removed in order to replace the hydraulic valve lifters. Do not remove or replace any intake camshaft valve train components.PARTS INFORMATIONPart NumberDescriptionQuantity11 33 7 605 330Hydraulic Valve Lifter (HVA)12Refer to EPC for additional gaskets, seals and bolts, as required by the Repair Instructions.WARRANTY INFORMATIONCovered under the terms of the BMW New Vehicle Limited Warranty, or the Certified Pre-Owned program.Please refer to the latest KSD for the applicable Main or Associated labor allowance for the specific model.Defect Code:11 33 93 39 00Labor Operation:Labor Allowance:Description:00 58 248 Refer to KSDReplace exhaust camshaft hydraulic valve lifters (HVA)*Main Workor00 58 827Refer to KSDReplace exhaust camshaft hydraulic valve lifters (HVA) [/QUOTE]
3 Series
E90, E91, E92, E93
