anaksarawak
Official Member
- Jan 20, 2007
- 4,154
:listen: Here a good deal for those who are looking for E46/E90 320 engine parts All items are compatible with N42 or N46 engine.
most if not all items are less than a year old as I have replaced them last year, price are 60% from what you quote from Bavarian Auto since its used.
I welcome everyone to NEGO till letgo.
Coolant (water) pump, mechanical 11517515778 RM200 (SOLD)
Thermostat 11537510959 RM100
Thermostat housing 11517572859 RM50
Power steering pump 32416780413 RM550 (SOLD)
Power steering OIL CARRIER/Bottle 32416851217 RM50
Intake manifold (Full set) 11617563837 RM600 cheaper if without sensors
Differential pressure sensor 13628617097 RM150
Actuator / motor 11617511383 RM190
Electric Fan housing with 300w Fan 17427563259 RM399
Ignition coil 12131712219 x 4 RM50 each
Rmfd generator / Alternator 140/150A 12317533270 RM399
Rmfd- Engine starter motor 12412354706 RM260
SOLENOID SWITCH 12417515393
wiring harness, engine ignition module 12517545173 RM100 if wires only
Engine wiring harness, engine module 12517549261 RM100 if wires only
wiring harness, engine trans. module 12517549271 RM100 if wires only
Throttle Body Housing Assy13541439580 RM399
FUEL TANK BREATHER VALVE 1 13907512576 RM100
BRACKET VENTILATION VALVE 1 13907509975 RM100
Fuel tank breather line 1 1390752976 Free if you take the above
INJECTION TUBE 1 13537530420 RM250
Cap 1 13537506155
INJECTION VALVE 4 13537506158 RM100 each must take all
EU4 exhaust emissions standard Whole set - catalyst "cleared" for performance with O2 sensors RM500, cheaper if you take the exhaust only. Great parts for those with blocked pipe, I used to pay RM1K for this
Rmfd exhaust manifold with catalyst EU4 1 03/2005 18407506561
REGULATING LAMBDA PROBE L=360MM 1 11787512975 RM200
REGULATING LAMBDA PROBE L=360MM 1 11787512976 RM200
Lambda Monitor sensor L=450MM 1 11787506539 RM200
Heat exchanger 1 11427508967 RM190 still new 2 months old
Vacuum pump 1 03/2013 11667542498 RM369
OIL SEPARATOR x2 11617503520 RM100
'Vent hose 1 11157503524 RM50
Connecting line 1 11157503523 RM20 Return pipe 1 11157513903 RM20
Solenoid valve (SOLV) 2 11367560462 RM200 each only 3 months old (new is RM380 each)
Camshaft position sensor 2 12147518628 RM100 each still new as I changed it 4 months ago (SOLD)
Actuator (valvetronic motor) 1 11377548387 RM600 as new is RM1100 from BA
MAF RM390 Hot-film air mass meter 1 13627566986
Cap 1 13537506155
