wingzee
- Mar 17, 2011
- 1,691
UDM #1 - Sold in August 2013
April 2004 BMW E46 325i Exclusive Edition with M-Tech II exteriors & 17" Style 68 M-Sport rims. Factory-equipped with Bi-xenon projector headlights with auto-levelling/auto lights, auto-wiper, electronic seats with memory and lumbar support, HiFi audio system with 10 speakers and amp, rear electronic roller blind, leather seats etc. Front and rear bumpers been converted to M-Tech II.Color is 317 Orient Blue Metallic.4th owner with 174,000km on the clock when purchased in April 2012. Currently clocking 192,000km and still rocking like a champion.List of mods done/in plan
art #1-- Huper Optik Ceramic C40 all round - Done-- BMW M3 SMG Steering Wheel /w Paddle Shifts - Done-- ///M Pedals - Done-- ///M Car Mats - Done-- Matte Black Kidney Grill - Done-- Custom European License Plate - Done-- Dominations ES61 Exzibit 6.5" 2-way Component Set (Front) + Macrom M3C.61 MkII 6.25" 2-way Coaxial Speakers (Rear) - Done-- License Plate LED - DonePart #2-- Matt Black Rear Diffuser - Done-- Dynavin DD Multimedia Player - DonePart #3-- Full Car Detailing (4-step polish + Permanon coating) - Done-- M-Sport Door Steps - Done-- LED Angel Eyes - Done-- M-Sport Electric Semi-bucket Seats-- Goodridge Brake Lines-- K&N Drop-in Air Filter-- Shadowline Trim-- ACS Roof Spoiler-- ZIZA Interior LED KitParts replaced/maintenance done:- New windscreen wiper garnish- ATF replaced 20k km ago with new ATF filter and sump gasket- All power steering hoses- Steering rack fully refurb with overhaul kit- New power steering pump- New power steering reservoir- New steering angle sensor- New steering coupling with lower joint and universal joint- Cooling system fully overhauled (water pump, radiator, expansion tank, all thermostats, caps and hoses, protected by BMW coolant & distilled water mixture)- New DISA/adjuster unit- Vacuum hoses- Fan belt- Fan clutch- ARB links L&R- Tie rods L&R- Meyle HD lower control arm bushes- Rear axle differential oil, all shaft seals, O-rings and centre bush- Long shaft bush and bearing- TITAN absorbers by Richard of MPD Auto with comfort sports setup, new mountings, bump stops etc.- New original BMW disc rotors (rear)- Fuel pump- Fuel filter- All new six Bosch spark plugs and ignition coils- Valve cover gasket- VANOS seals- New roof lining done by Ah Kit of Top Cushion- New hood sensor- New boot handle- New light cover strips L&R- New rear ashtray- Flywheel oil seal- Torque converter oil seal- ATF with new ATF filter and sump gasket (March 2013)- New power window switch (front, passenger)- Engine mountings- Gearbox mountings- New side signal indicators (fender)- New BMW brake fluids- Gearbox heat exchanger (replaced with air-cooled from E36)- Steering column assembly and shaft- New Zimmermann cross-drilled disc rotors with Z coat (front)Parts/maintenance pending:--Cooling coil + air-cond service RM2000--Crankshaft sensor RM185 (VDO)--Camshaft sensor (intake) RM208 (Vaico/Hella)--Camshaft sensor (exhaust) RM170 (Vaico/Hella), RM377 (BMW)--Alternator RM750 (Bosch)--O2 sensors (Pre-cat) #1 - RM343 (Bosch)--O2 sensors (Pre-cat) #2 - RM387 (Bosch)
