Gb problem 318 m43
subraputra
Official Member
Hi guys,
Yesterday on my way to jb in 130km/h my car suddenly become free.so I park the car on the road side safely and try to shift the gear to D the car do want move.check the engine side no leaking gearbox no leaking.try to shift S and manual also nothing.pls give some advice. ..
Cheapest & fastest option buy Japanese used unit from chop shop. Best but very costly option is full overhaul. Could be anything from RM6-8K.
No point taking advise for cheap repair work because it just won't work on GM gear boxes. Probably last a short time only. End result you pay much more plus more frustrations.
GM gear boxes cannot just replace the oil seals or just clean the valve body or replace solenoids. The pistons inside the GB needs replacement too & that's when a full overhaul becomes costly.
Hi guys yesterday I try to dismantle the gear box.i found the torch converter slot key which is located in after the oil seal broken and cause the gear box never angage.
