Error : Check Park Lights (but no blown fuse!)
hofmeister
Banned
hi guys,my car experiencing this strange problem. trying google up and down also can't find solution.just change to a set of new headlights. after plug it in, the error check park lights keep warning me on my dash.i've checked, low/high beam/ angel eyes/fog lights/signal light all working.i found out there is a weird symptoms whenever the error came out. whenever i switch on my angel eyes only, the right signal will light up(not blinking) for a minute then it goes off.any idea ?
Parking light is the the light u switch the signal on after engine off. Some wiring are wrong between the angel eye and signal bulb. Yours is prefacelift car? Changed to Hella or Depo headlught?
Are you using the original park light bulbs or after-market LED's?
Any difference in bulb wattage can cause the warning light.
hofmeister;610594 said:
after market's. but its still working.
Check the bulb wattage. Even if it's working, but it draws less current than the original bulbs, the car will think it's malfunctioning - so you get the warning light.
