engine swap,e30 to e21
eau-rouge
the engine is m20b20..1.can i use the e30 braking system?servo all that..including rear discs2.use the original e21 radiator or change it?3.steering rack can fit or not?will be using the e30 dashboard..4.rear axle need to change?thanks
thanks
bro
M20 engine can go in E21 body
1. brake servo can go in but, need some modify
rear disc E30 can't fit in E21
totally is two different body and axle
except u cut it and welding body
ask inchiwan2. he using volvo type to modify
2. use back original E21 radiator, i think E30 radiator too big
3. steering rack of course can't fit-lah, E30 more longer
dashboard can-lah
4. rear axle not need to change
propellar shaft change only
that is my opinion :p
thank u
any E21 sifu please give idea to eau-rouge :lol:
the engine and gearbox already fit in.the problem now is the radiator.as im using auto trans now,i need to change the radiator too.really hard to find e21 radiator for auto trans.can i use e30 radiator?the small one
Hv u tried 1st division, CSS, Bomin or Munich auto to source for radiator... check it out...
Or if can go near any abandon e21, see if it is auto, hence the radiator can be acquuired...
e30 small radiator maybe possible, but need to confirm on mounting points, and hoses shapes and fittings for coolant/water flow from engine to radiator vice versa...
good luck...
