V-Man;835554 said:As the title goes, my ride is vulnerable to these thief's... Is there a way to reprogram the ECU /EWS ? instead of changing the entire ignition, alarm and locking
What are the alternatives... Gimme some input techies :smokin:
jarance;835628 said:You can disable the stolen key by recoding it the EWS.
by recoding the ews, the car cannot start but the key can still open the lock manually.
ICEMAN 68;835635 said:don't tell me the keys of the 330 was inside the stolen Volvo ?
i think you need to change the entire set up ... try calling bernard ..that SG guys ...who know he knows how to do it ...
if the thief is smart enough then he will be able to reenable the key to be working. i guess that process is quite straight forward.jarance;835628 said:You can disable the stolen key by recoding it the EWS.
haywire;835703 said:Can use pa soft to disable the key, no need quotation la
V-Man;835959 said:cool...if this PA Soft can do the trick on a SMG 330i, why not.. thanks for the info
infinityKL;837224 said:they took the plastic key too
what is it for?
thank you
