E39 - CD Changer (Stock)
msian
Hey Guys, anyone experience this issue?I pressed the eject button and cartridge does not come out. I can hear the mechanism sounds though but nothing happens. Any advise?
Found this on the net:
I had this problem and did a bunch of searching on the net until I found the answer. There's a place the magazine hooks or clicks into that eventually wears and the magazine warps due to the heat in the trunk over time. You need a thin piece of hard cardboard, thin plastic ruler or something like that (a credit card is not long enough to reach the latch). It needs to be about 4 or 5 inches and strong enough to pop the latch. Slide it down on one side and pull it across. I can't remember which side you do it on, but I think it's right to left. If not, try the other side. I had to play with it a bit but after about 5 minutes of fiddling with it I got it to unlatch so I could pop it out.
thx, i just pushed the changer inwards and pressed the eject button. tried a few times. now its popping out
YaZmEeN;626600 said:
Bro, u got ur car already....?
Hello Bro!
Yes, today morning everything finalised. Started driving today, loving it! Thanks to your recommendation bro. Cheers to you!
Also will require your assistance in clearing out the front lights when possible.
