E39 Angel Eye Ring Replacement..
James Chun;700237 said:
Good Day,
Anyone here can show me the way to replace the ring light at E39????thanks!
Can tell more specific ? U want to replace the light bulb or replace the e39 angel eye ring ?
Good Day,
U can replace the bulb to change the angel eye color.
Anyway to get brighter eye, u may consider the LED which need u to open the lens cover from the headlight body.
Bro, my single-LED is direct swap, not as bright as multi-LED but easy to install/replace.
Thanks for all the Information. Actually initially I want to replace the angel eye ring...But today morning I "ketuk" it, surprisingly the ring turns on again..may be some wiring connectivity problems...Anyway, I know the bulb can directly change to colour from yellow to white...Bro 7833...how can the angel eye ring change colour by only changing the bulb to white colour??
If your headlight is post angel eyes headlight then it only a plastic ring which will transfer the light. Before the light transfer to this plastic ring it has fiber optic cable which will transfers the light to plastic rings. No matter what color of light that you put then it will transfers the light to the ring and shows the color light that you want.
If you mentioned the light is CCFL ring then you have to replace the CCFL ring in order to display different colors.
Tweiboon is right.
U can replace the T2 bulb in order to get the color u prefer.
Dear all...i not sure whether it is T2 bulb or LED type??? how to confirm??I just see another 2 socket behind the headlight other than 2 main hH7 blub socket...any idea??
This is original angel eyes bulb:
This is LED replacement bulb:
Finally i get to know that my angel eye is using the original one...can i buy the replacement LED type..just plug in????
James Chun;700819 said:
just turn clockwise or counterclockwise to open the socket???same like H7 socket??
Yes just turn.
James Chun;701630 said:
no error message right if buy the replacement LED type??
I believe the replacement LED will come with an extra cable to render it error-message light free.
